Old 04-01-2016, 02:49 AM   #1
scubie.brz
Drives: hyper blue BRZ
Ace 4-1 header???
Just wondering if anyone has tried or heard of any power gains or results from the Ace 4-1 header i've been looking for headers to increase power gains for my brz but also want to be able to use the same headers for when I go FI. I spoke to a rep at ptuning (the turbo kit I am leaning towards) and they said the ace 4-2-1 header wouldn't work with their kit because of the overpipe combo. So I am debating on getting the 4-1 header since it doesn't seems I can use any overpipe. Any recommendations or experience with the Ace 4-1 header? PLS help LOL
scubie.brz is offline   Reply With Quote
Old 04-01-2016, 03:27 AM   #2
juliog
juliog's Avatar
Drives: 86
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
go_a_way1 (04-04-2016)
Old 04-01-2016, 04:03 AM   #3
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Official release of these new headers will be at the Taiwan's Auto Parts Exhibition April 6.
Anaconda 48mm for high horsepower (application and approval required. 1-2 month lead time).
Anaconda 42.7mm for anything under or around 400HP.
Headers will have package deals if using Ace OP. Headers also work with majority of other aftermarket OP's.
Will be available through Ace directly (www.aceheader.com), CSG (www.counterpacegarage.com) or Abbey Motorsports in UK (http://www.abbeymotorsport.co.uk/)
AceHeader-MT is offline   Reply With Quote
The Following 2 Users Say Thank You to AceHeader-MT For This Useful Post:
churchx (04-02-2016), CSG Mike (04-01-2016)
Old 04-01-2016, 02:22 PM   #4
86Tony
Drives: 2015 AOZORA EDITION
i personally think this header makes the most power
86Tony is offline   Reply With Quote
The Following 2 Users Say Thank You to 86Tony For This Useful Post:
AceHeader-MT (04-01-2016), CSG Mike (04-03-2016)
Old 04-02-2016, 08:24 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
86Tony: At top rpms? Very probable. Shorter runners hint for that. But will it have biggest gains area under curve? Imho less probable. How often/long on average do you spend (even on track) at 6500-7500? Yes, it might be very track/gearing specific but my very wild guestimate is that "averaged" header like A250 may bring more average gains at average tracks one sees. And if daily driving is considered, then nothing will beat A350/CS400. That "most power" will mean nothing but bragging rights with dyno numbers, if you don't drive mostly at header's narrow optimized rpm range and actually use that more then for brief second before upshift. And that needs specific tracks and good skill-set imho. Not everybody is like CSG Mike, after all
The Following User Says Thank You to churchx For This Useful Post:
Old 04-03-2016, 02:57 AM   #6
We've found that the A/350 is the best overall header of the 150/250/350 group for overall driving.
Sleepless (04-03-2016)
Old 04-03-2016, 05:45 PM   #7
JGalp
Drives: 2015 CWP BRZ Limited
moreso than the CS400? i pretty much live in the 3000-5000 RPM range. hardly am i shifting above 6000 for my DD purposes. (no track autox)
JGalp is offline   Reply With Quote
Old 04-04-2016, 01:10 AM   #8
I haven't had enough experience to say with the CS400, but the A/350 is excellent.
Old 04-04-2016, 01:14 PM   #9
CSG David
CSG David's Avatar
You're getting a lot of love from CSG with two different perspectives!
CS400 is great for DD use, however, the overall powerband is the most generous and the best with the Type-A 350.
Old 04-04-2016, 01:21 PM   #10
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Are you running with the Ace front pipe for DD? Worried about droning without a catted fp
Sleepless is offline   Reply With Quote
Old 04-04-2016, 05:27 PM   #11
Drone will be completely determined by your catback. With the stock catback there is zero drone. ZERO.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
driftking96 (02-08-2017), funwheeldrive (04-04-2016), go_a_way1 (04-04-2016)
Old 04-04-2016, 05:42 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Lifes too short for stock
and he is right, catback will determine drone, so dont cheap out there either.
Old 04-04-2016, 07:21 PM   #13
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Perrin 2.5" resonated?
Old 04-04-2016, 09:03 PM   #14
scubie.brz
Any experience with a tomei type 80 catback with the ace 4-2-1 header type A 350 i've seem to make up my mind on which header but haven't heard what the header will sound like with the exhaust. Also any info on custom fabrications for turbo set up with ptuning turbo kit or the avo turbo kit?
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
