Old 03-31-2016, 04:07 PM   #1
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
Rattling lower center console dash cubby hold
Anyone had any success getting this to stop rattling? It's held in by 6 clips. I have the BRZ limited so it is the one with the start button. When it rattles and I press on the frame top/bottom in the center, it stops rattling. There's grooves around the perimeter of the hole where it fits into, there's probably about 2mm of space where it inserts.
'14 BRZ CBS
>>Pretty Stock
a_dee is offline   Reply With Quote
Old 03-31-2016, 04:10 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
well then fill the 2mm with something and report back ??
Old 04-01-2016, 12:09 AM   #3
_gt86_user
Inactive
Drives: .
Use thin buffer tape and re install should fix the issues, once I applied on the cubby and master window switch rattles were gone.
_gt86_user is offline   Reply With Quote
Old 04-01-2016, 12:12 AM   #4
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
Thanks for the reply gt86, what exactly is thin buffer tape?
'14 BRZ CBS
>>Pretty Stock
Old 04-01-2016, 08:43 AM   #5
Ashikabi
Ashikabi's Avatar
Probably double sided tape(the thick foam kind). I'm guessing he's not from Murica so they use different names sometimes. We are taking about the one next to the usb directly below the had unit right? Can you pull it out and reinstall it? That thing fits pretty tight I'm surprised it can rattle
Old 04-01-2016, 09:44 AM   #6
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
I had a rattle in that area in my FR-S. Turns out to be a loose cable and dealer tied it up for me. Fixed.
Sent from my Nexus 6 using Tapatalk
aa_chow is offline   Reply With Quote
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Dash is rattling like woah KevinBRZ Issues | Warranty | Recalls / TSB 11 10-08-2013 09:41 PM
OEM dash or center console buttons, help identifying. Rumbaar Cosmetic Modification (Interior/Exterior/Lighting) 2 09-04-2013 03:46 AM
Center Console Rattling Fixed!! Ericfrs Scion FR-S / Toyota 86 GT86 General Forum 8 08-07-2012 10:01 PM
FR-S / FT-86 Colors, Instruments, and Center Console/Dash Now Revealed Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 202 11-25-2011 08:21 AM
