Old 03-31-2016, 01:25 PM   #1
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Idea for map sensor.
Hey, guys. Just a thought, here. Back in the day, we'd use a "boost blocker" to keep the map sensor from seeing any boost. It made the tuning easier, by keeping the ECU from freaking out.
I've only ever seen them for the 2-bolt map sensors on Hondas and old school Subarus. It was a little metal gizmo with a check valve, about 2in x 1in. I have not seen one in years. I don't even know if they make one to fit the BRZ's style of map sensor.
Just a thought.
Subzero is offline   Reply With Quote
Old 03-31-2016, 01:31 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just a thought.
or you know just buy a proper MAP sensor? They are not expensive
Old 03-31-2016, 01:37 PM   #3
Subzero
Old...
Subzero's Avatar
Drives: Subaru
These ECUs kind of hate them from what I gather. It was an old trick worth mentioning.
Old 03-31-2016, 02:11 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I have ran an omni 4 bar past 30psi with no problems on mine. sounds like a tuner problem, not a map sensor problem. my maf maxes out on my setup, my ecu would be going at it blind if the map sensor was being cheated
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
go_a_way1 (03-31-2016), Sportsguy83 (03-31-2016)
Old 03-31-2016, 02:12 PM   #5
Subzero
Old...
Subzero's Avatar
Drives: Subaru
http://www.treadstoneperformance.com...k+Check+Valves This thing
Old 03-31-2016, 03:09 PM   #6
mrk1
Drives: Sterling BRZ Ltd
No MAP sounds like a terrible idea.
I see a lot of user error with the MAP, not sure why.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 03-31-2016, 03:41 PM   #7
empower-auto
Kouki-Monster
empower-auto's Avatar
This is some of the dumbest s__t I've read on here since day 1.
Buy a proper MAP sensor. Don't be cheap. Like .. Delicious Tuning gives you an 11psi Bosch sensor for pretty much nothing. If your ECU doesn't "like" the map sensor it's probably because you're a dingus and just tossed a different sensor in without making appropriate adjustments.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Old 03-31-2016, 05:50 PM   #8
FRS Justin
Drives: 2013 Asphalt FRS
I guess you could bolt a carburetor on it too................
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
go_a_way1 (03-31-2016), mrk1 (03-31-2016)
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Idea for 10 Series Owner, but have no idea how to accomplish. IgnitionGundam Cosmetic Modification (Interior/Exterior/Lighting) 9 10-01-2013 12:29 AM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
