Old 03-31-2016, 04:26 AM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Pad shims on ap racing / essex caliper
Looking at trying some shims to reduce / eliminate the pad squeal. Has anyone already tried this?
Manji is offline   Reply With Quote
Old 03-31-2016, 04:27 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
What pads? With brand new pads I not sure there is room for shims also lol
My 1521 are silent.
Old 03-31-2016, 05:19 AM   #3
Manji
Manji's Avatar
Shims are very thin. Every decent pad I've tried is hideously loud. Many I've used the same compounds in other calipers and never had anywhere near as much noise as I have with this caliper.
Old 03-31-2016, 08:36 AM   #4
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
I ran the wilwood shims in my AP calipers on the wrx (same caliper body) with DS2500's and it didn't completely eliminate the noise but it did reduce it a decent amount.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
Manji (04-02-2016)
Old 03-31-2016, 09:39 AM   #5
ubernostrum
Drives: 2013 Subaru BRZ Ltd GBS 6MT
I run some titanium shims with the Carbotech 1521 street pads. The shims plus some anti-squeal grease between the shim and the pad makes it nice and quiet. But it does nothing for the XP10 track pads. The grease would just burn off and the sound is the same with or without the shims.
ubernostrum is offline   Reply With Quote
The Following User Says Thank You to ubernostrum For This Useful Post:
CSG Mike (03-31-2016)
Old 03-31-2016, 10:28 AM   #6
1521 should be 100% silent even without shims.
Properly bedded Project Mu 999 are 100% silent, but bedding them may be a real challenge without going out of your way to specifically do it.
ZionsWrath (03-31-2016)
Old 03-31-2016, 01:59 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
But what pads?
Old 03-31-2016, 02:23 PM   #8
IPGJames
Drives: ...Cars...
my HPS pads for street are quiet (thank god)
my DS1.11 for the track are quiet for a day or 2 after track use but then annoying
i just got used to swapping
problem solved
i did use some of the anti squeal grease the first time i put the HPS on and i didn't think twice about it when i went to the track next with the DS1.11...after the first session and back in the pits it was like the front left corner was on fire with the amount of smoke coming off as the grease burned off, drove it around for 10 minutes to give it more cool down time...lesson learned
IPGJames is offline   Reply With Quote
The Following User Says Thank You to IPGJames For This Useful Post:
Old 03-31-2016, 04:56 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
problem solved
YES. Swapping wheels and brakes for track might be a little time consuming but it is so worth it. Short of trailering your car I think its the best move.
Old 03-31-2016, 07:03 PM   #10
Estey
Drives: Scion FR-S, Ultramarine
problem solved
Do you swap your rotors too, or is that unnecessary?
Estey is offline   Reply With Quote
Old 03-31-2016, 07:05 PM   #11
ZionsWrath
Thanks
ZionsWrath's Avatar
I've found no need to swap rotors. The braking takes a couple laps to get on point but after that its fine. Swapping back in street pads I don't find any problems after the track day.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Estey (04-01-2016)
Old 04-01-2016, 08:23 AM   #12
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Had my Sprint kit wailing like a dying Banshee even after bedding both Hawk HP+ and CL RC6E pads on the track. I'm currently using Carbotech AX6 for street use and it's totally quiet. So I guess there is no dual purpose pads that will stay quiet on the street. Best thing to do is just to swap them for different purpose.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 04-01-2016, 08:33 AM   #13
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I can play music with my DS2500s a week or two after a track day. Bedded as per instructions. Can deal with it more than I feel like swapping pads. Anything to quieten would help.
86•BRZ is offline   Reply With Quote
Essex/AP Racing BBK Owners Please Read...We Need Your Help! JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 07-28-2016 08:06 AM
RR-Racing Sport Performance and AP-Racing Essex Initial Comparison Gear_One_Performance Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 04-20-2016 04:31 PM
FS: Essex AP Racing Sprint Kit + Many Extras Hanakuso Brakes, Suspension, Chassis 1 11-30-2015 11:12 PM
AP Racing / Essex brake kits fit 16's? Yes! And even 15's!! diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-06-2013 07:07 PM
