Drives: 2013 Raven FR-S
OFT 93 Map Throttle Issues
Has anyone else noticed hesitation sometimes when blipping the throttle while using the 93 map? When I'm at a stop and rev the engine a bit before engaging the clutch, I've noticed this. It doesn't happen all the time, but pretty often. Weird thing is it never seems to happen when using the E85 map. Just curious if anyone else has noticed it?
#2 | |
Drives: 2023 GR86 - Track BRed Premium 6M
Yep, I am hoping the new version of the 93 map fixes the throttle issue.
STR also-ran
| The Following User Says Thank You to TRACE_on For This Useful Post: | smg1138 (03-30-2016) |
I would look the load limits
some usa tunes C and D series had load limits set to 1.5 across whole range copy the load limits from a G series rom into your C or D series if they are set high. copy both load limit tables you will need wayno's defs from this post http://www.ft86club.com/forums/showthread.php?t=83945 |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 01:20 PM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 01:44 PM |
| Anyone having throttle issues? | FRiSson | Issues | Warranty | Recalls / TSB | 13 | 09-25-2012 06:35 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 08:44 PM |
