Old 03-29-2016, 06:35 PM   #1
Kiwis
Kiwis's Avatar
Drives: 2016 Blackout BR86
BRZ Bumper to FR-S Bumper
So I recently purchased a '16 Subaru BRZ Limited (Black) and thought it was the greatest purchase... until a week later when I began noticing the FR-S/GT-86 on the road with their clean grills minus the horrid BRZ "mustache." That in mind, I had a few questions someone is hopefully able to answer.
This afternoon, I visited my local Subaru dealership and spoke with a rep about the possibility to switch out my front bumper for a FR-S one. Was told it was entirely possible and we ended up finding this piece online:
http://www.discountbodyparts.com/det...PS010343P.html
Now, I noticed the material states "plastic" and I asked the rep what the current BRZ bumper was made of: turns out it's yet another style of plastic, just a bit reinforced. That said, would the above work properly with a BRZ frame? They're almost identical bodies so I wouldn't see what the difference would be other than fog lights and bit of extra visibility to the top of my headlights. If it's not suitable though, what's a good alternative as nobody seems to be selling their FR-S bumper standalone.
In addition, with the switch of the bumpers, looked into replacing the Subaru badges with 86 badges found here:
http://koreanautoimports.com/3d-soli...rs-subaru-brz/
Does anyone have experience with the company above or seen the badges in real life to note if they're a high quality product or if I should look into legitimate Toyota badges?
Kiwis is offline   Reply With Quote
Old 03-30-2016, 09:20 PM   #2
Kiwis
Kiwis's Avatar
Bump?
Old 03-30-2016, 09:45 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
No experience with that site/mfg but I run an FRS bumper on my BRZ in the winter to keep my lip minty fresh.
Either it will fit great, or it's a low quality party that fits bad.
Edit: Also no reason to bump after a few hours.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 03-30-2016, 11:51 PM   #4
8R6
8R6's Avatar
Drives: FRS
bumpers are interchangeable and will fit fine. you'll just have a small gap in the inside corner of your BRZ headlights and you'll also have nowhere to plug in your lower drl's. and then the frs signals would be unused since yours are inside the headlights already.
8R6 is offline   Reply With Quote
Old 03-31-2016, 07:10 AM   #5
Kiwis
Kiwis's Avatar
Alright do you recall where you purchased yours personally? I really don't want to spend money on a lousy part to just have it sit around provided it's not the proper one.
Also, made sure to wait well over a day to bump (around 26-27 hours).
Old 03-31-2016, 07:54 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Toyota dealer would be where to purchase an FRS bumper new. You have a new car.... IF you HAVE to swap this out at least do it with factory parts.
Old 03-31-2016, 08:01 AM   #7
Kiwis
Kiwis's Avatar
Simple reason for switching it is I love the FR-S, the BRZ just had everything included without paying the extra fees and such. Also, the drive to the Scion dealership is an hour for me whereas Subaru is all of 5 minutes up the road. Also, thanks for that note, guess I'll be taking the hour long drive to hit up a Scion dealership and find a front bumper.
Old 03-31-2016, 08:04 AM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Didn't ask about reasoning. I considered doing the switch because if you look at WRB brz's with FRS fronts they look awesome. Someone mentioned turns and fogs above, definitely things to consider when you plan this out, it isn't just as simple as a bumper swap.
Not too complicated, but there are a decent amount of parts to do this correctly without making it a hackjob.
Old 03-31-2016, 08:13 AM   #9
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I considered this too as my brz bumper is pretty beat up. To solve the useless lights in the FRS bumper Id suggest doing the fog light delete panels with the brake ducting? That would probably look nice rather then having lights that aren't hooked up.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-31-2016, 08:42 AM   #10
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Definitely go OEM. You can usually find them on eBay from wrecked cars for a decent price if you're lucky in your color if not repaint it. Good luck!
Old 03-31-2016, 08:57 AM   #11
Kiwis
Kiwis's Avatar
Researched that already, most of them are cracked and have dents galore in it. Honestly I'll either take my chances with something online or contact a dealership.
Old 03-31-2016, 10:41 AM   #12
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
I just did a quick search for a BRZ front bumper because I was thinking of replacing it since I have so many scratches/bugs/buildup on it that it just won't come off with cleaning supplies. It's OEM and unpainted for $226 from subarupartsamerica.com. I'm thinking a FRS/86 bumper should cost around the same. I'm not sure how much it would cost to paint it and if not would it be a close match.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 03-31-2016, 10:59 AM   #13
Kiwis
Kiwis's Avatar
Searched up "OEM FR-S Bumper" and found this:
http://parts.olathetoyota.com/scion/...e=bumper-cover
Didn't even consider the above (searched for an OEM specific part) so it definitely makes a huge difference. Not too expensive in comparison to the other part found earlier, hoping to get an email back from my local Scion dealership to see if they give a price similar especially since it's local.
As for paint, contacted my local Subaru and their onsite bodyshop stated that a front bumper for a BRZ/FR-S would be around $200-$300 @ ap5512.
Old 03-31-2016, 11:06 AM   #14
Summerwolf
Panda Trueno
Summerwolf's Avatar
Then new bumper clips, grille, turn signal area / fog light housing, fog light / turn signal assemblies (or brake ducts) bumper pad, badging, removal of the headlight surround....etc etc.
bumper swap, debadge
anyone want a BRZ bumper? --Dark Grey front bumper swap Charlotte NC IroncladBRX Southeast 0 04-20-2014 09:18 PM
WTT(Midwest): MY 37j(pearl white) FR-S bumper w/fogs for YOUR BRZ limited bumper OmarGC Exterior Parts (Aero, Lighting, Etc.) 26 12-02-2013 11:44 AM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
