Old 03-27-2016, 02:47 PM   #1
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
Question with used catback exhaust
Hey everyone, I am gonna purchased a used Greddy catback exhaust system, now with that said, the seller said he has the installation part, is it okay to reuse those parts or is it recommended to get a new one instead?
Also how do I test it for leaks? and make sure that its installed properly?
Thanks!
xFury is offline   Reply With Quote
Old 03-27-2016, 03:54 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
get new gaskets, all you need.
Dr. BRZ is offline   Reply With Quote
Old 03-27-2016, 04:49 PM   #3
humfrz
Thanks!
Well, you can try the old parts ..... if they leak ..... get new gaskets.
An exhaust leak can usually be "heard" ...... and/or will leave a sooty streak around the leak.
humfrz
Old 03-27-2016, 09:19 PM   #4
xFury
xFury's Avatar
Sweet, and for the gasket, is there a certain place I should get it from? Or any auto store should work?
Thanks!
Old 03-27-2016, 09:29 PM   #5
humfrz
Thanks!
Most auto stores should have them. However, I would take the old ones in to make sure they match.
humfrz
Old 03-27-2016, 10:24 PM   #6
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Thanks!
I had an exhaust leak with my dezod exhaust gaskets. I went and got OEM ones from Subaru and they work.
Just sure they are the same size piping
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-28-2016, 01:11 PM   #7
xFury
xFury's Avatar
humfrz
I'll give the current one on the OEM a try and see if it would work, hopefully it does lol, if not I think I can pick up that Grimmspeed one locally.
Thanks guys!
Old 03-28-2016, 02:54 PM   #8
Ashikabi
Ashikabi's Avatar
Fteightysix sells grimmspeed and oem
Some question about m7 catback exhaust.. 86wtywly Engine, Exhaust, Transmission 11 10-13-2015 03:42 PM
Header/non res catback question Pryz228 Engine, Exhaust, Transmission 0 08-09-2014 12:40 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
HKS Catback Exhaust Group Buy - Legamax Premium Exhaust & Hi-Power Spec L Catback FT-86 SpeedFactory Groupbuys 11 10-21-2012 08:59 PM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 12:24 PM
