Old 03-26-2016, 08:54 PM   #1
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
St coils front coil binding
I just bought used st coils with front top hats. i have coil binding issue which is probably caused by the MOTORSPORTS top hat. anyone else running into coil binding issue which causes a twang sound? any fixes? I heard grease helps but i think that's only temporary
shaynek is offline   Reply With Quote
Old 03-26-2016, 09:03 PM   #2
swarb
http://www.summitracing.com/parts/aaf-all64210
http://shop-fortune-auto.com/collect...-sold-in-pairs
thrust washer or thrust bearing or radial bearing. Even something as simple as a delrin washer may work.
The Following User Says Thank You to swarb For This Useful Post:
shaynek (03-26-2016)
Old 03-26-2016, 10:28 PM   #3
shaynek
shaynek's Avatar
Which one do you recommend for a more quite ride?
Old 03-26-2016, 10:54 PM   #4
swarb
If coil bind is the issue then they would all work.
What top hats do you have? Are the springs seated correctly?
Old 03-27-2016, 01:44 AM   #5
shaynek
shaynek's Avatar
I have MOTORSPORTS top hats. yea they are seated correctly from what i can see. i bought them used with the coils pre-assembled.
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
OEM Pipes Front to Muffler and a Spark Coil. trsiidno Engine, Exhaust, Bolt-Ons 19 07-16-2015 02:12 AM
Coil Binding on Coilovers ericmpena Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 03-08-2015 01:54 AM
Window gasket binding FRiSson Issues | Warranty | Recalls / TSB 3 12-19-2012 04:16 PM
