Old 03-25-2016, 10:52 PM   #1
alchemy
Drives: 86 GTS 2015
86 GTS HID Headlights Point Too Low
I drive a Toyota 86 GTS from Australia. Our cars are specced with HID xenons and LED DRL's.
My problem (and also a lot of fellow owners' problem) is that our headlights point far too low, making the total reach on flat ground maybe 10-20 metres. At night time, I can barely see anything ahead, even on flat ground.
Is there any way we can adjust these headlights to make them point up more and therefore project further?
I know in the FRS and GT models there is a manual headlight levelling switch next to the steering wheel column, however our GTS headlights come with automatic headlight adjustment and therefore that manual levelling switch isn't there... and the auto headlight adjustment keeps pointing it down too much :/
alchemy is offline   Reply With Quote
Old 03-25-2016, 11:09 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I thinks that's how the car is. I thought that the headlights were pointed too low even at the highest setting (highest being 0).
N1rve
Old 03-25-2016, 11:31 PM   #3
ryoma
ryoma's Avatar
pop your hood and look behind your headlight housing. there should be an 8mm or 10mm hex head with a phillips in the middle (it is plastic on the BRZ). clockwise brings it down and counter clockwise raises it I believe. it is best to do it at night with your headlights pointing at a wall so you can see the cutoff moving up and down.
The Following User Says Thank You to ryoma For This Useful Post:
alchemy (03-27-2016)
Old 03-26-2016, 09:05 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Wasn't there autoleveling, that needed adjustable aftermarket bit (by cusco or DIY), for cases where car height was lowered?
Old 03-26-2016, 09:30 AM   #5
ARTBRZ
Aloha!
ARTBRZ's Avatar
What this person said above. I had my headlights replaced under warranty and the tech didn't even know about the manual adjustments. I had to do it myself.
ARTBRZ is offline   Reply With Quote
Old 03-26-2016, 10:09 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
They definitely point low. But most of my local roads are lit so I havent fucked with it but I def notice it on night backroads
Old 03-26-2016, 11:08 AM   #7
SlammedSilly
Drives: 2015 Ultramarine FR-S
on a good note the highbeams on the frs are fucking amazing. you can literally see everything, haha. i honestly dont think they point low, but thats just me, im used to the lights i guess
SlammedSilly is offline   Reply With Quote
Old 03-27-2016, 06:13 AM   #8
alchemy
Drives: 86 GTS 2015
Hm thanks, this sounds promising, I'll give it a try tonight!
Old 03-27-2016, 08:57 AM   #9
alchemy
Drives: 86 GTS 2015
Ok I had a look and tried my best to find aforementioned hex head but found nothing. All I found was a slothead thingy (pointed to it in my attached pic).
Am I looking in the wrong place? Or maybe it's just a BRZ thing?
Attached is a pic of what I looked at (headlight housing behind left headlight)
Old 03-27-2016, 09:32 AM   #10
ARTBRZ
Aloha!
ARTBRZ's Avatar
Eureka! That's the one.
Here's a video.
[ame]http://youtu.be/hye_OnwEyTs[/ame]
The stock headlights has a plastic knob instead of metal in the video.
The Following User Says Thank You to ARTBRZ For This Useful Post:
Old 03-27-2016, 11:49 PM   #11
alchemy
Drives: 86 GTS 2015
Here's a video.
Thanks a lot for your help! Just tried it and am so happy with the results. I should've done this ages ago!!
Everyone should do this if they feel that their headlights point too low! Super super easy to do and very worth the 5 minutes
Old 11-16-2020, 09:17 PM   #12
quickboiau
Drives: 86
This thread was a life saver - thanks!
quickboiau is offline   Reply With Quote
The Following User Says Thank You to quickboiau For This Useful Post:
Wally86 (11-18-2020)
WTT: Trading my blacked out OEM headlights for your stock chrome headlights DCStorm Exterior Parts (Aero, Lighting, Etc.) 7 06-28-2015 11:01 AM
GT86 headlights vs. Maserati Ghibli Headlights l0aded Scion FR-S / Toyota 86 GT86 General Forum 7 08-29-2014 08:39 AM
What is the point of this car? dem00n Scion FR-S / Toyota 86 GT86 General Forum 88 10-09-2012 03:31 AM
