Old 03-25-2016, 10:09 PM   #1
atlbrz
Drives: Hyper Blue BRZ
Camber bolts and toe alignment
I pick up some camber bolts for my 2016 BRZ. Visually I can see the added camber. Based on some crude camber devices, the front, maxed out on the bolts, is very comparable to the rear camber. I am guessing around 1.0 degrees. I was worried about the change on the front toe from adding the camber bolts and increasing front camber. I check the front and rear toe today and was a bit surprised by the results. The rear shows around 1/16 total toe in. The fronts are very close to zero toe. I didn't measure the toe before adding the camber bolts. Perhaps the toe was off some from the factory. Does the BRZ gain or lose toe with increased camber. Granted it is only around 1.0 degree decrease, but I didn't know how much the toe would change. Comments?
atlbrz is offline   Reply With Quote
Old 03-25-2016, 11:00 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
The front toes in when adding negative camber. That said, the tie rods iare not very far out of plane of the control arm so change is not drastic.
Old 03-26-2016, 10:54 AM   #3
Ashikabi
Ashikabi's Avatar
I think 1/16 is pretty close to spec, both front and rear change with camber but its a small change. I wouldn't worry about it. Or get an alignment, shouldn't need toe arms though
Old 03-26-2016, 12:36 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Can anyone quantify the amount of toe added per unit of camber in front?
Old 03-26-2016, 01:31 PM   #5
Ashikabi
Ashikabi's Avatar
I'm curious about this too. It must be a set quantity per degree
Old 03-26-2016, 08:02 PM   #6
atlbrz
I was just surprised the toe didn't change or changed very little. I should have checked the toe before adding the camber bolts. Even just picking up around 1.0 degree negative camber from the camber bolts made a big difference on the feel and turn-in on the front end. Now the front end doesn't feel like it just wants to push in the corner. Best $10 I ever spent.
Old 04-05-2016, 11:38 AM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
I'll just leave this here
Old 04-05-2016, 11:41 AM   #8
Ashikabi
Ashikabi's Avatar
Good link
Old 04-05-2016, 07:22 PM   #9
freerunner
freerunner's Avatar
Drives: GT86
Hmmm. Adding camber via bolts should not change toe more than a negligible amount.
Messing around with camber plates is a different story. It's the pivot point. Caster, camber, toe and even effective spring ratio can be influenced by moving that point around.
Very powerful in skillful hands, but prone to errors if not done right.
freerunner is offline   Reply With Quote
Basic Noob Questions - Camber bolts/alignment/etc Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-28-2015 01:59 PM
What is needed for a proper alignment after lowering 1in? LCA's, Camber bolts? CallmeDave Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 05-17-2015 09:26 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Front Camber Bolts / Alignment Question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-17-2013 04:31 AM
Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. Shiro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-14-2013 09:44 AM
