Old 03-21-2016, 03:52 PM   #1
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
DFW FT86 Shops
I've got a cam carrier leak which means pulling the motor to fix. Since the motor is out I plan to do some other mods.... clutch, flywheel, motor mounts and etc.
Any suggestions on where to go?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 04-09-2016, 09:42 AM   #2
Aaronimoe
Hey Blake, you ever get this taken care of? Any progress reports?
Aaronimoe is offline   Reply With Quote
Old 04-09-2016, 11:11 AM   #3
Bramick
Bramick's Avatar
Ordered a cam plate, so far no more leaks.
Old 04-09-2016, 11:12 AM   #4
Bramick
Bramick's Avatar
http://www.torquesolution.com/product-p/ts-cam-plts.htm
Old 04-09-2016, 11:20 AM   #5
Aaronimoe
Awesome. How did you first notice the leak?
Old 04-11-2016, 10:06 AM   #6
Bramick
Bramick's Avatar
Smell cause the exhaust runs right under it. If it starts leaking it'll be the bottom side first. So look for drops on the pan right below.
Old 04-20-2016, 08:41 AM   #7
pleong
Drives: 2013 Whiteout FR-S
PRT Performance in Lewisville removed built and replaced my motor. They've done a few others as well
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 04-20-2016, 08:44 AM   #8
Bramick
Bramick's Avatar
Thx. I plan to use them. My issue ended up being the cam carrier plate. 2 weeks in and no leaks. I'm planning to do another deep inspection this weekend.
I have some tuning needs coming and PRT sounds like the best option
Old 04-20-2016, 12:05 PM   #9
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I can vouch for steve at PRT. Very knowledgeable, and was great working with him as I coordinated a dyno day with shiv.
malubawla is offline   Reply With Quote
Old 05-11-2016, 12:55 PM   #10
C3
C3's Avatar
Drives: Scion FR-S
Have any shops in the DFW area installed the full blown stage 2 kit?
C3 is offline   Reply With Quote
Old 06-17-2016, 09:37 AM   #11
pleong
stage 2 turbo kit? or stage 2 heads?
Either way, PRT Performance has done both.
Old 06-18-2016, 12:29 AM   #12
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
how much was labor at PRT to build your engine out of curiosity, already using Killer Hot Rods for my wide body as suggested by you so may as well look into using another shop you suggest
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 06-22-2016, 06:26 AM   #13
pleong
It was $3,000 for the labor which includes removing and replacing the engine back into the car.
I provided all the parts and I also had them machine and clean the block and balance the crank which was about another $450-$500
I think it was an additional $300 since I had a turbo kit. So all together it was about $3800.
Old 06-22-2016, 10:14 PM   #14
Bramick
Bramick's Avatar
Not bad. I was expecting more.
[||•]=(FT86)=[•||] SWITCHBACKS | LED DOMELIGHT | MORE LEDS --> [||•]=(FT86)=[•||] 86SPEED Interior Parts (Incl. Lighting) 10 10-25-2018 03:13 PM
Evasive FT86 Service & Maintenance Thread Discount Labor for FT86 Members Evasive Motorsports Southern California 423 10-01-2018 12:49 PM
FT86 parts/shops in Europe? Wyllliam Scion FR-S / Toyota 86 GT86 General Forum 6 10-17-2013 12:05 PM
shops in la... itdansharpe Cosmetic Modification (Interior/Exterior/Lighting) 0 04-29-2013 01:12 PM
AB shops PowderfaceTr. CANADA 0 09-24-2012 02:04 AM
