I'm New
Drives: 2016 Limited Subaru BRZ White Pearl
K&N or WORKS Drop In Performance Air Filter?
Hello, I've been looking to replace my OEM air filter with either a K&N or Works filter. What I would like to know is which one is better and pros and cons of each one. Which do you prefer? Any input or advice would be greatly appreciated. Thank you!
"You do you"
Drives: GTS 86
SAME stuff different name! Get whichever is cheaper.
Although I know I'm not directly addressing your question, I have a Cosworth drop-in filter and I've been impressed with its quality, fit, and performance - the engine definitely feels like it's more willing to rev. The bottom line: If you haven't made your purchase already, the Cosworth filter is something you should consider along with the K&N or WORKS units you mentioned. Highly recommended.
Last edited by RJasonKlein; 03-21-2016 at 02:10 AM. Reason: Corrected a typographical error. |
#4 | |
Drives: Sterling Silver BRZ
I do have a slightly better mpg rating after installing it and the intake sound is a little louder aswell.
Drives: 2013 satin white brz limited
I have k&n was fairly inexpensive.
| The Following User Says Thank You to jasonojordan For This Useful Post: | Chrisgalactic (03-21-2016) |
[||]--(86)--[||]
Drives: 2015 Firestorm FR-S
I'm not familiar with the Works filter and heard a lot of good things about the K&N being the best value.
I picked up a Blitz filter over the winter and will be installing it once the cars out. A fun read: http://www.ft86club.com/forums/showthread.php?t=13245
[||•]==(86)==[•||]
Seems to be the collective opinion, pick your favorite color or brand and just buy it, you shouldn't notice a difference of one from another.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| The Following User Says Thank You to 15limited For This Useful Post: | Cole (03-21-2016) |
Drives: Subaru BRZ / Toyota 86 Experts
Stock air filter works pretty well. The aftermarket ones require you to clean them more frequently and we find that a bit more work than necessary!
Drives: 2013 Raven FR-S
flip a coin.
#10 |
Drives: World Rally Blue BRZ
Got the Cosworth airfilter recently to replace my filthy Apexi one.
The cosworth filter really looks similar to the apexi one, I would suggest the Apexi one for the cost. Good alternatives to look at as well. |
#11 |
Drives: WRB Limited BRZ
KNN is a lot cheaper, and probably outputs the same benefits as any other drop in air filter.
| The Following User Says Thank You to Alltezza For This Useful Post: | Chrisgalactic (03-21-2016) |
#12 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
and there my friends is the difference, all other filters you have to replace and buy new ones expect for KN, they are lifetime reusable.
#13 |
Scooby***s Guy
Drives: 2019 Impreza Sport - MT
I use to use K&N filters for years starting on my motorcycles back in the 80's. I put one in my 2004 Forester XT but it the gauze weave started to look shabby after a few cleanings. I read about a similar style (oiled gauze) by Green Filter. I don't know if anyone else is familiar with this brand but IMHO it's quality is better. I've decided to order one for the BRZ but if you want to see some comparison pics (Green VS OEM VS K&N) of the forester one I have them here:
http://www.scoobymods.com/showthread...71.html?t=2271 I will report back when I get the filter and take some comparison pics. The Green Filter number for the BRZ is "Green Filter 2319" I got mine on Amazon, the price is comparable to a K&N but honestly I think the quality is better. The weave seems less likely to shrink and the pleats are constructed. More of an FYI, when I get the BRZ I will report back. Link to the filter directly http://www.greenfilterusa.com/store/2319 You can find them a lot cheaper on line than the cost there.
~peaty
2019 Impreza 5 Dr - MT, 2023 Forester Limited - 2001 Miata SE, MT. Kids 2023 BRZ Limited MT, Kids 2015 Crosstrek Premium CVT |
#14 |
Drives: 15 BRZ LTD, 05 FXT
I like the dryflow filter options, oil can get on the MAF and cause failures/malfunctions.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| FS Works Drop-in Air Filter | azngolfur | Engine, Exhaust, Bolt-Ons | 11 | 09-27-2013 01:34 PM |
| WORKS DROP IN FILTER | Julio86 | Engine, Exhaust, Bolt-Ons | 3 | 09-04-2013 12:41 AM |
| Works Drop in filter delivery | btd800 | AUSTRALIA | 5 | 03-22-2013 04:50 AM |
| WORKS Resonated AB and Drop in filter | phenom86 | Engine, Exhaust, Transmission | 90 | 02-28-2013 09:44 PM |
| WORKS Resonated AB and Drop in filter | phenom86 | Southern California | 21 | 11-05-2012 01:27 AM |
