Old 03-20-2016, 05:39 PM   #1
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Invidia Q300 Owners have this water?
I currently have Invidia Q300 and i was changing my oil today.
i noticed that some kind of fluid on my drive way so i thought it was oil was leaking from drain bolt but it wasnt.
I found out it was water from Q300 at muffler (both sides but i only took picture of one side)
I am wondering other Q300 owners have this as well.
Should i concern on this? i think it's just moisture got up and turned into water when muffler got hot.
any comment?
Old 03-20-2016, 05:43 PM   #2
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Quite normal on any car with a muffler...on an internal combustion engine.
After turning off the engine, the dry, hot interior of the exhaust system pulls in moisture from the air...water vapor.
You may have noticed from the rear, a car just started cold. Water comes out of it's exhaust...the water which went in there after the engine was turned off.
Some mufflers may have a drain hole for excess water to exit...yet certainly not all mufflers.
And many mufflers have a fiber material within (muffler packing...designed to change the muffler's sound during engine running conditions), which can soak up water, holds it...until the later hot muffler dries it out.
You might question Invidia as to what they may use for muffler packing.
ToySub1946 is offline   Reply With Quote
The Following 2 Users Say Thank You to ToySub1946 For This Useful Post:
FRSBRZGT86FAN (03-20-2016), zc06_kisstherain (03-20-2016)
Old 03-20-2016, 09:31 PM   #3
navanodd
Drives: 2013 BRZ Sport-tech WRB
Also, water is a byproduct of combustion. When your car is running, it is a vapor, but it will condense in the cooler portions of your exhaust and even more once the engine is stopped.
Its one of the big reasons (plus NOx) that exhausts corrode from the inside-out.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
Old 03-20-2016, 09:57 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have not noticed this on my Q300, but it is probably excess moisture like everyone said.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 03-20-2016, 10:19 PM   #5
zc06_kisstherain
Drives: SWP BRZ
i usually noticed this at exhaust tip but never seen dripping water from muffler.
as long as i dont have air leak, i should be fine. so i was making sure.
thanks for quick responses~!
Old 03-21-2016, 02:57 AM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you are dripping from the muffler and there are no visible marks of water dripping down from a flange or exhaust tip, your muffler canister is not 100% sealed and has a leak, and it should be fixed or warrantied.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Tcoat (03-24-2016)
Old 03-21-2016, 09:19 AM   #7
zc06_kisstherain
Drives: SWP BRZ
-alex
damm...i got it as used. i dont think i see dripping water...
what method do i need to seal it there?
EDIT: i researched little but isnt that like weep hole to escape some of water?
hope other Q300 owners chim in
Old 03-24-2016, 03:44 PM   #8
twag4
Drives: frs
I have it. Good thing it is stainless steel. I live in the humid south, so I consider condensation on anything a normal part of life
twag4 is offline   Reply With Quote
Old 03-24-2016, 03:58 PM   #9
mav1178
mav1178's Avatar
I think you need a better picture of the overall setup and where the water is coming from.
The problem with these muffler endtank design is that it is just stamped steel w/ a rolled edge. Sometimes they weld it shut, but if it's weeping water out of the edge (and not from the tips) then there is a way for moisture to rust and cause a leak later on.
It may be perfectly fine now, but depending on usage you may be replacing the canister or rear muffler sooner than you wanted.
The first mufflers on the market 15-20 years ago often were all mild steel w/ coating, and the resonators would have to be replaced often since any defects in internal welding would cause them to leak and rust through prematurely. Modern exhausts are stainless steel and less prone to rust, but it still happens as the methods of manufacturing are still the same.
-alex
Old 03-24-2016, 04:13 PM   #10
zc06_kisstherain
Drives: SWP BRZ
-alex
Better picture of where? That area is where water i saw. Other areas of muffler is fine. Thanks for explanation. I drive my car 1-2 times per week and i didnt check often. This was i noticed first time.. I will keep checking if it doesnt happen again then it is moisture got up there.
Old 03-24-2016, 04:19 PM   #11
mav1178
mav1178's Avatar
Better shot of entire canister and possible sources of water. All I can see is the edge of the canister, not the entire endtank or other parts of that muffler.
-alex
Old 03-24-2016, 04:27 PM   #12
zc06_kisstherain
Drives: SWP BRZ
-alex
Checked entire canister and no water but that area. So i only took picture that edge.
Owners of Invidia Q300 lxsedan Engine, Exhaust, Transmission 59 08-24-2020 11:49 AM
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 09:21 PM
FS: Invidia Catless Front Pipe/ Invidia Q300 Exhaust Parts timmydatooth Engine, Exhaust, Bolt-Ons 27 04-04-2016 09:46 AM
Invidia Q300 catback & Invidia catless front pipe: 2015 Subaru BRZ WhenzLunch Engine, Exhaust, Transmission 5 02-09-2016 10:18 PM
FS: Invidia Q300 & Invidia Front Pipe DR1FT Engine, Exhaust, Bolt-Ons 15 06-07-2013 07:29 PM
