Old 03-20-2016, 02:43 AM   #1
Ryguystye
Drives: 2014 BRZ Premium
Does this Car Push/Roll Start?
In the event of the battery being too low to start normally, can I start this car with a push/roll? Or do the modern ignition and fuel systems require me to use jumper cables?
Ryguystye is offline   Reply With Quote
Old 03-20-2016, 02:47 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
If it's manual and the ignition is in the on position you can push start it like any other manual car with a dead battery. The ecu tune does the same process as it would do when the starter kicks over fuel injection or not.
But it's no substitute for not having jumper cables in your car to help a friend or something, you can practice it a bit if your bored honestly up a hill or down a incline in reverse or 1st I used to do it when I had a manual corolla, but don't keep doing it repeatedly for no reason.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (03-20-2016), Tcoat (03-20-2016)
Old 03-20-2016, 03:11 AM   #3
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
What about cars with keyless entry/push start?
I like driving!
86 South Africa is offline   Reply With Quote
Old 03-20-2016, 10:00 AM   #4
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
I've bump started my car before. Same experience as doing it to a car from the 60s, the only difference is that this car WREAKS of gas for about 5 min afterwards.
pushrod is offline   Reply With Quote
The Following User Says Thank You to pushrod For This Useful Post:
Tcoat (03-20-2016)
Old 03-20-2016, 10:23 AM   #5
steve99
yes works fine
push start button twice without depressing clutch to turn ignition full on.
Then clutch in push car select a gear and let clutch out.
with all modern cars though you need enough power in battery to run the ecu and ignition/injectors for a push start, so if battery is completely dead theirs no chance. Only works if battery just not strong enough to turn starter motor
86 South Africa (03-20-2016)
Old 03-20-2016, 10:26 AM   #6
You would have to be rolling when you pushed the button and there would have to be enough charge left in the battery for the circuit to sense the fob and know you pushed the button. It may work but would be very tricky and I don't think it would be a good idea to try it.
Edit: Not fast enough again. What Steve said^^^
Old 03-20-2016, 10:37 AM   #7
ls1ac
ls1ac's Avatar
He is right on, there has to be enough of a charge to fire the coil packs. Unlike the cars of old the push will not spin the alternator fast enough to charge the ignition system. It takes a lot more to spin the starter, as you will notice every thing going dim. Starting in second gear is also easier as you are not turning engine over as fast. Lastly, if you use a toe strap you can charge a dead system but be aware the car will jump forward when it starts so use a longer tow strap.
Old 03-20-2016, 11:27 AM   #8
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
I read somewhere (including manuals of FRS and of other cars) that with pushstarts there is a danger of overheating/fire of the catalytic converter. I it's about unburnt fuel getting there before the engine starts running. No idea though how real the danger is.
mdm is offline   Reply With Quote
Old 03-20-2016, 03:22 PM   #9
FRSBRZGT86FAN
Doubtful, there are many other situation where with a tune where unburnt fuel enters the exhaust stream when the engine is essentially off throttle.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
mdm (03-20-2016)
Old 03-20-2016, 03:37 PM   #10
Not to mention that if you have raw fuel in that quantity pouring into your cats then the engine is going to be so badly flooded that it will not start anyway. Without starting there is no heat to ignite the fuel.
Not sure but doubt it would burn even if running though since the exhaust gases would likely deplete the oxygen to below the level required for combustion. Could be wrong on that though since I have no idea what the oxygen level in exhaust gases may be.
FRSBRZGT86FAN (03-20-2016), mdm (03-20-2016)
Old 03-20-2016, 03:53 PM   #11
86 South Africa
Best I don't let my battery die then! :-)
I like driving!
Old 03-20-2016, 04:10 PM   #12
mdm
not a twin owner
mdm's Avatar
Without researching it any more, I'd theorize the following scenario.
During Several unsuccessful attempts at push-start the air-fuel mixture flows through the engine and fuel is collected in cold cat. When the engine ultimately starts, the cat heats up, and suddenly you have a significant amount of fuel in the presence of very hot catalysts, and things get nasty.
One thing that my brilliant theory does not explain, is why things would be any different if a few unsuccessful starts using the starter are followed by successful start.
The Following User Says Thank You to mdm For This Useful Post:
Tcoat (03-20-2016)
Old 03-20-2016, 04:21 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
meh
MTpockets (03-20-2016), Tcoat (03-20-2016)
Old 03-20-2016, 04:45 PM   #14
Nope No fires in the exhaust of a running car. Just as I thought there is just not enough oxygen to burn the fuel. Now if you don't evaporate it all and shut it down allowing the oxygen to enter the system...
Cole (03-21-2016), FRSBRZGT86FAN (03-20-2016)
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Push start driftartist Electronics | Audio | NAV | Infotainment 2 08-26-2012 10:17 AM
push to start pa2gamer02 BRZ First-Gen (2012+) — General Topics 6 03-17-2012 01:01 PM
