Old 03-16-2016, 12:31 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Whiteline Com 'C' Strut Mounts
I remember a while back people having problems with these clunking and popping. Does anyone know if Whiteline ever fixed that issue? I think it was related to the open bearings they were using.
smg1138 is offline   Reply With Quote
Old 03-16-2016, 10:52 PM   #2
df.dima
Drives: FR-S and Mazda 3 Sky
As far as I remember reading in other threads, they gave up and pulled the plug on those...
df.dima is offline   Reply With Quote
Old 03-17-2016, 05:41 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
I noticed that FT86speedfactory still has them on their site. Maybe you should contact them to see if they have any in stock.
Old 03-17-2016, 05:43 PM   #4
Calum
That Guy
IIRC someone posted that they changed the bearing. I think they ended up using the same bearing as OEM, but with a metal seal.
Old 03-18-2016, 01:56 AM   #5
cnk
Drives: '13 DGM BRZ Limited
They changed the bearing, but it didn't fix the issue. They actually sent me a new set with a couple machined washers that they said they were testing. I didn't want to go through the hassle of swapping them to only have issues again so I went with HVT mounts and haven't had any problems.
I still have the Comp-C's NIB if anyone is interested. Otherwise, was just going to throw them up on Nasioc for a WRX/Impreza owner instead.
Old 03-18-2016, 08:30 PM   #6
Calum
That Guy
Like this?
Old 03-18-2016, 09:06 PM   #7
cnk
Originally Posted by Calum View Post
Like this?
Nope. That's the Subaru conical washer. I was running those and still had bearing problems. The ones they sent me look like this:
Old 03-18-2016, 10:37 PM   #8
makinen
makinen's Avatar
Drives: Toyota 86
I think its bearing axis should be inclined somewhat.
I've tried conical washers but bearings failed in the same way.
makinen is offline   Reply With Quote
Old 03-19-2016, 01:10 AM   #9
wparsons
wparsons's Avatar
They still make them, but don't list them for the FRS/BRZ. They don't have issues on the impreza chassis, but something about the strut angle on these cars doesn't play nice with the bearing.
flickr
Old 04-17-2018, 03:25 PM   #10
norcalpb
norcalpb's Avatar
Bringing this back from the grave, has anyone ever had a set that didn’t make noise long term??
Old 04-17-2018, 04:17 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
I managed to get wished camber & keep rubber top mounts via other means. -3 at stock height with camberbolts in both holes + powerflex bushing PFF69-801G. Pitty about no non failing bearings revision of compatible Com-Cs for twins, but i got what i wished at end.
Old 04-17-2018, 09:21 PM   #12
norcalpb
norcalpb's Avatar
What a shame. I’m considering group N rubber top hats but they do not have nearly the same benefits as a silent Com C would have.
Old 04-17-2018, 10:17 PM   #13
Racecomp Engineering
One of the products we'd love to make is a long lasting fixed camber plate with some rubber for reasonable NVH. Got a couple other things in the pipeline in the meantime, but hopefully we can make something like that in the future.
- Andrew
Old 04-17-2018, 11:44 PM   #14
whataboutbob
AutoX-10/10ths every run
I'd suggest just buying the RACESENG CASCAMs and be done with it. I have been through the COMCs previously and they never lasted.
http://www.raceseng.com/cascam-caste...ubaru-brz-2013
Build thread:Here
Whiteline Com-c top mounts sw20kosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 349 05-27-2015 06:15 AM
