Old 03-14-2016, 02:16 PM   #1
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Wheels Size and AutoX
This may of been asked and it may of been asked 100x, but in my basic searching I cannot find much info.
I was looking at getting 18" wheels. I did some AutoX and it is very easy to understeer with stock tires. Yes, I know it is the driver too. A lot of it is me pushing too hard and not driving well, but the stock tires don't help. I have only had understeer issues at the autox course(s) so far.
Would upgrading to 18x8/8.5/9/9.5 be a good upgrade, or should I stick to 17" wheels with new rubber, or 17" and get wider wheels?
I planned on getting 18x9.5 in the rear and 18x8 in the front to fill in the wheel gap and get better traction, but I don't want to wait to buy my wheels and the set I was looking at was more than I can spend right now.
I am making absolutely sure that the wheels weigh less than the 17s I have. I have a series.blue and from my research the wheels are 19-21lbs each. I am looking at the Motegi MR131 Traklites. They only come in 18x8. The price is nice, and the weight is even better! I don't necessarily like the wheels, but the price + weight are nice, so I figured I would go with that.
Is there any reason I shouldn't go with 18"? Is 17" > 18"? And lastly, should I go with something that is 18x9.5" in the rear, or will 18x8 (all around) do the trick?
Thanks in advance for the help, and sorry if this has been asked before. I couldn't find much.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 03-14-2016, 02:17 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
your post is too long. and your search fu is weak.
Go with wheels as light as you can, I would stick with 17 inch, run 245 rubber thats the basic recipe/starting point for autoX
edit: just glaced at your post and saw you are thinking about staggered, that will give you a lot of under-steer dont do it lol!
Old 03-14-2016, 02:33 PM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
What's your alignment look like? You're going to want more negative camber in the front if you're at OEM alignment specs.
Don't stagger your wheel sizes. If you want to stay in SCCA C Street, you have to stay 17x7, but you can go lighter. Most autocross folks are running 17x7 or 17x9 depending on which class they're in.
18" will make your ride harsher, may likely increase unsprung mass, and slightly improve steering response. 17" is better for ride quality and easier/cheaper to keep the weight down. Tires are also significantly cheaper in 17.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
gtslow (03-14-2016)
Old 03-14-2016, 03:27 PM   #4
strat61caster
strat61caster's Avatar
Changing tires won't fix your handling problems, at best it will mask the problems by adding enough grip that you're not driving at the limit of the grip available so your times improve and everything feels great, until someone steps in behind the wheel actually drives it at the limit, or you step up your game and the problems return. At worst it could actually exacerbate the problem, especially as the tires wear in an imbalanced fashion.
What classing and ruleset are you building to? This can be extremely restrictive to your wheel and tire choice and buying what you want without looking will put you into a class where you will be noncompetitive unless you spend $5k, $10k, $25k on modifications adding more lightness, power, and grip.
If you're just doing it for fun, awesome! Do what you want.
My 2 cents are, again, tires won't solve anything. From a stock setup the thing most lacking is camber on the front end. Adding camber up front will add grip on the front tires when turning reducing understeer, camber bolts will put you in the -1 to -1.5 degree range, a big improvement over stock which is usually less than -0.5 and perfectly streetable. With bolts and camber plates you can run up over -3.0 degrees which felt great for me, what you do will depend on the class you want to run in.
The two most common classes for autocrossing an 86 are SCCA CS and STX. With CS you are limited to OE size wheels and OE crash bolts, STX opens up a lot of possibilities but you're looking at around $5k to get in the ballpark in terms of tire, suspension and power and some real talent to get it dialed in.
ineedyourdiddly
Old 03-14-2016, 04:23 PM   #5
AFRichZC6
AFRichZC6's Avatar
@strat61caster has hit all the big points. I'm just going to piggyback on it.
The stock tires DO help you learn! You'll learn to control the car better at the limit when the limits are so much lower on the stock tires vs sticky ones. With stickier tires, the limit is higher, and they will be less forgiving when you eventually exceed that limit. I'm a believer of the whole "the easier to learn, the faster you learn" philosophy.
If you get a staggered wheel/tire setup, you'll likely just get more understeer. The guys in in STX usually run a square setup - typically 17x9 with 245/40R17. This will offer loads of traction when combined with some more camber adjustment. I'd play around on the stock setup or a CS-prep if you're still learning. I compete in C-Street with a second set of 17x7 wheels with my autocross-dedicated tires.
I haven't seen anyone competitive in our region in CS or STX classes with 18" wheels. Tires will probably be more expensive too. It's not worth going to 18" wheels unless you want the look or if you are going to run something wider than a 255/40R17, but you may want more power to make up for increased rotating mass.
I do about 4 or 5 events on stock wheels and tires before I started adding the OEM camber bolts, front sway bar, and got a dedicated set of used wheels and tires. A year later, I got Koni dampers.
AFRichZC6 is offline   Reply With Quote
The Following User Says Thank You to AFRichZC6 For This Useful Post:
strat61caster (03-15-2016)
Old 03-14-2016, 04:24 PM   #6
Strife26
Strife26's Avatar
If I wanted to go with 9" width, does that fit the front? I thought the widest you could get up front was 8"? That was why I was looking at staggering, not necessarily because I wanted to.
I would be Auto crossing just for fun this season as I am new to it all. Learning and enjoying mainly this season.
I was looking at doing little mods here and there. Tires/wheels, springs, sway bars etc, and brakes.
I wanted to start with tires/wheels.
Old 03-14-2016, 04:34 PM   #7
Strife26
Strife26's Avatar
Thanks all. Now to start the hunt all over. I am mostly a car newb and I was set on 18". I will look at 17" now, or maybe just buy new tires and stick with the stock rims. I do like them, being that it is the series.blue and not the other version.
Old 03-14-2016, 04:41 PM   #8
gtslow
Drives: 2015 Halo FR-S
Add the $20 OEM camber bolts and an alignment then autocross on your stock tires for this season. You can decide if you want to stay in C Street or move up to STX. You can play around with your tire pressure as well if you find that the stock tires are rolling over.
gtslow is offline   Reply With Quote
The Following User Says Thank You to gtslow For This Useful Post:
strat61caster (03-14-2016)
Old 03-14-2016, 05:03 PM   #9
ka-t_240
Agreed, get some camber in the front, and get a bit more seat time.
17x9 does fit correctly on stock suspension, pending offset and tire size. I ran 17x9 +42 with 245 tires on stock suspension for a season. I was stock alignment tho. The car was much better with just the tires.
I wouldn't suggest spending the money on another set of 17x7 wheels unless you make up your mind that you will keep yoru car as a CS car, personally, it was never an option for me so I went traight to a 17x9.
ka-t_240 is offline   Reply With Quote
Old 03-14-2016, 06:29 PM   #10
Strife26
Strife26's Avatar
I want to go to 17x9, but maybe I will just upgrade the tires since I need to anyways for daily driving. I'll wait till I am a bit better at Autox before I buy wheels.
Does that sound like a good start? Camber bolts/alignment and new tread.
Maybe I will just buy some better brake pads for now instead of the wheels.
I also have not upgrade my fluids. I really need to do that!
Thanks again for all the help so far.
Old 03-14-2016, 06:45 PM   #11
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Getting into autox the cheapest upgrade that worked well for me was brake fluid swap. But I didn't do a front camber bolt. Having experienced 1.5 degrees of front camber I can now honestly say that is the best bang for your buck.
If you do that and new rubber on stock wheels; you can stay in CS and put up some competitive times. I did one year this way, then just tires the next year (17x8 though), and now for my third year I'm taking all that money I saved and doing a more complete STX package for the car. Early on, I wasted all of my money on seat time, and I continue to prioritize that.
Just my 2 cents in the bucket...
GeorgeJFrick is offline   Reply With Quote
The Following User Says Thank You to GeorgeJFrick For This Useful Post:
Strife26 (03-14-2016)
Old 03-14-2016, 06:51 PM   #12
xwd
I'm not a believer in autocrossing on crappy stock tires to learn something, the car behaves very differently on them than any real performance tire. Sam Strano (many time national champ) said the same thing when he was still on here. Tires can hide bad driving, but you also can't progress very far on the stock tires.
I would get tires first and autocross in CS (basically stock) class to start with.
The stock brake pads and fluids are fine.
Old 03-14-2016, 06:52 PM   #13
AFRichZC6
AFRichZC6's Avatar
The stock pads are pretty capable for autox. It was the last thing I did besides exhaust. I'd keep the stock tires on - I still have them for daily driving. But you do you.
Old 03-14-2016, 07:07 PM   #14
Strife26
Strife26's Avatar
I am going to upgrade the tires. I planned to anyways. I have been fairly mean to my stocks knowing they aren't great. I have just under 30k on them.
I am not sure if my driving is good or bad, but I definitely had understeer a lot on the course they made up. I do canyon runs often and don't have issues with cornering there, but I also don't push as hard considering blind corners and possible civilians/cars.
I dropped 7 seconds by my second run. I was initially just driving, not worrying about the apex etc. I was also playing with the stock tires sliding a bit.
I have a full 2.5" exhaust, short throw shifter, lightweight pullies (I know), and the OFT.
Custom size wheels shultz2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 01-19-2018 09:05 PM
WTB Black size 18 wheels FRS'd Want-To-Buy Requests 4 03-18-2016 01:55 AM
Bridgestone RE-71R: Best size for AutoX smg1138 Tracking / Autocross / HPDE / Drifting 3 08-28-2015 09:51 PM
What size wheels did you put on your cars? gt8613 BRZ First-Gen (2012+) — General Topics 24 02-09-2014 11:08 PM
16" autox wheels Jeffsu350 Tracking / Autocross / HPDE / Drifting 13 05-02-2013 08:52 AM
