Old 03-09-2016, 12:37 PM   #1
dallenj
Drives: Grey FR-S
After Market Cam Shafts
Who make a good cam shafts for these cars. I am making a nitrous build and looking to get some more air flow. Piper did, but they just removed them from their site. Hks makes stroker cams. Just trying to find out some options.
dallenj is offline   Reply With Quote
Old 03-09-2016, 12:39 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
fullblown
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-09-2016, 12:48 PM   #3
dallenj
Drives: Grey FR-S
Originally Posted by spitfire481 View Post
fullblown
Full blown cams are a regrind not a set of cams if I'm not mistaken.
Old 03-09-2016, 12:51 PM   #4
spitfire481
Drives: 2JZ FRS
this is true, but they work just as well. you need to re shim the valves either way so its not really a problem
MoTeC
Build Thread
@spitfire481
Old 03-09-2016, 12:54 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Unless you are doing pistons you wont gain much with cams, the valve clearance is already too tight
Old 03-09-2016, 01:09 PM   #6
dallenj
Drives: Grey FR-S
I have read that's why not many companies are doing cams is because the stock cams are so good, but I have seen a power increase from the piper shots on another page on this forum and it interested me in what else was out there.
Old 03-09-2016, 01:15 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
not because they are good, but because there is no room.
Old 03-09-2016, 01:25 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
^THIS
They are not bad cams by any means, however there is just no valve clearance. If you get some custom pistons and custom cams done up you can make some good gains, but at that time your also going to want to port the exhaust side. Its only a matter of money and the dollar to performance gains is not worth it IMO if you want to go that route.
Old 03-10-2016, 08:56 AM   #9
Ashikabi
Ashikabi's Avatar
What these guys said. No valve clearance. I'd spend my money elsewhere
Old 03-10-2016, 01:35 PM   #10
celek
Resident Gear Head
celek's Avatar
I little birdy told me someone on the West coast is pricing billet blanks out right now
Currently HKS is the only other manufacture offering true aftermarket cams not reground OE cams
celek is offline   Reply With Quote
Old 03-10-2016, 01:54 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
To get a true blank, ground to any spec, youd need to redesign the heads. Spendy spendy.
Driveshaft Shop Carbon Fiber Shafts Explained Driveshaft Shop Engine, Exhaust, Transmission 121 11-17-2017 11:57 AM
Installing new axles (drive shafts) ChrisD Engine, Exhaust, Transmission 9 07-11-2015 06:49 PM
Carbon Drive Shafts, ACT, Cusco, Whiteline - All at RallySportDirect.com! RallySport Direct Transmission and Driveline 3 08-16-2013 07:51 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 04:55 PM
