Old 03-09-2016, 02:31 AM   #1
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
So I snapped the OEM camber bolt.
Snapped the top camber bolt somehow. 3 inches lowered -1.5 degrees prior.
No clue how I did it. Just thought it was interesting.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-09-2016, 07:54 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
You sure it didn't just back out and fall off? That's crazy if it broke though
Old 03-09-2016, 07:58 AM   #3
stevesnj
stevesnj's Avatar
I believe that's a grade 10 bolt. Snapping one requires tremendous force. That just fell out.
My 2016 Build thread
The Following 4 Users Say Thank You to stevesnj For This Useful Post:
GeorgeJFrick (03-09-2016), go_a_way1 (03-09-2016), JakeRogue (03-09-2016), wparsons (03-09-2016)
Old 03-09-2016, 08:26 AM   #4
Ashikabi
Ashikabi's Avatar
Gonna agree with Steve. I think the knuckle would be pretty deformed. Use more torque next time. Maybe a dab of locktight
Old 03-09-2016, 09:43 AM   #5
Rifle
Rifle's Avatar
I mean, it could have backed off. But it was tight as fuck. Not like it's my first coil job lol. The bottom one is solid. I just have no idea where the top one is/went.
295WHP/220TQ
Old 03-09-2016, 09:46 AM   #6
Ashikabi
Ashikabi's Avatar
Maybe the thread was dirty so it seemed tight? I dunno. I'm betting it takes many tons of pressure to shear that thing. Something else would break first
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 03-09-2016, 09:48 AM   #7
jasonojordan
Drives: 2013 satin white brz limited
You would rip the mounting hole on the coil before you would shear that bolt.
jasonojordan is offline   Reply With Quote
The Following 2 Users Say Thank You to jasonojordan For This Useful Post:
go_a_way1 (03-09-2016), wparsons (03-09-2016)
Old 03-09-2016, 09:50 AM   #8
adamg
Drives: brz
Nothing against camber bolts i use them myself to achieve -5 up front but why are you using camber bolts if your only running -1.5. You can achieve that with just your top hats.
adamg is offline   Reply With Quote
Old 03-09-2016, 10:04 AM   #9
Cole
Not a troll
Cole's Avatar
Easier to do fine adjustments with a camber bolt vs a top hat
Old 03-09-2016, 10:43 AM   #10
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I think he meant the OEM flange bolt.
jawn is offline   Reply With Quote
Old 03-09-2016, 11:26 AM   #11
stevesnj
stevesnj's Avatar
Did you use a torque wrench when you tightened it down? Too tight will cause stress and failure
The Following User Says Thank You to stevesnj For This Useful Post:
Thorpedo (03-09-2016)
Old 03-09-2016, 11:39 AM   #12
Rifle
Rifle's Avatar
This. Yeah, it's the OEM bolt. I do my camber adjustments via top hats. No idea how it happened.
295WHP/220TQ
Old 03-09-2016, 01:44 PM   #13
stevemp5
Drives: scion fr-s
may be just a neighbor who wanted you dead
stevemp5 is offline   Reply With Quote
The Following User Says Thank You to stevemp5 For This Useful Post:
Old 03-09-2016, 01:45 PM   #14
Ashikabi
Ashikabi's Avatar
This.
Camber bolt on KW V3 derek1ee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-25-2017 11:21 AM
Camber bolt help oofie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-22-2013 01:36 PM
strut brace bolt snapped frs10 Issues | Warranty | Recalls / TSB 19 10-31-2013 02:37 PM
strut brace bolt snapped-need help frs10 Issues | Warranty | Recalls / TSB 9 10-20-2013 01:29 AM
