| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
So I snapped the OEM camber bolt.
Snapped the top camber bolt somehow. 3 inches lowered -1.5 degrees prior.
No clue how I did it. Just thought it was interesting.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#2 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
You sure it didn't just back out and fall off? That's crazy if it broke though
#3 |
I believe that's a grade 10 bolt. Snapping one requires tremendous force. That just fell out.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following 4 Users Say Thank You to stevesnj For This Useful Post: |
#4 |
Gonna agree with Steve. I think the knuckle would be pretty deformed. Use more torque next time. Maybe a dab of locktight
#5 |
I mean, it could have backed off. But it was tight as fuck. Not like it's my first coil job lol. The bottom one is solid. I just have no idea where the top one is/went.
295WHP/220TQ |
#6 |
Maybe the thread was dirty so it seemed tight? I dunno. I'm betting it takes many tons of pressure to shear that thing. Something else would break first
| The Following User Says Thank You to Ashikabi For This Useful Post: | JakeRogue (03-09-2016) |
#7 |
Drives: 2013 satin white brz limited
You would rip the mounting hole on the coil before you would shear that bolt.
#8 |
Drives: brz
Nothing against camber bolts i use them myself to achieve -5 up front but why are you using camber bolts if your only running -1.5. You can achieve that with just your top hats.
#9 |
Not a troll
#10 |
Drives: 2015 CWP BRZ Limited
#11 |
Did you use a torque wrench when you tightened it down? Too tight will cause stress and failure
| The Following User Says Thank You to stevesnj For This Useful Post: | Thorpedo (03-09-2016) |
#12 |
This. Yeah, it's the OEM bolt. I do my camber adjustments via top hats. No idea how it happened.
295WHP/220TQ |
#13 |
Drives: scion fr-s
may be just a neighbor who wanted you dead
| The Following User Says Thank You to stevemp5 For This Useful Post: | go_a_way1 (03-09-2016) |
#14 |
| Camber bolt on KW V3 | derek1ee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-25-2017 11:21 AM |
| Camber bolt help | oofie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-22-2013 01:36 PM |
| strut brace bolt snapped | frs10 | Issues | Warranty | Recalls / TSB | 19 | 10-31-2013 02:37 PM |
| strut brace bolt snapped-need help | frs10 | Issues | Warranty | Recalls / TSB | 9 | 10-20-2013 01:29 AM |
