Old 03-06-2016, 08:27 AM   #1
soccerk18
soccerk18's Avatar
Drives: 2013 WRB Limited
Pieces of Tire Coming Off?
I just got my tires rotated yesterday and I noticed that on the inside of my right front tire (used to be right rear) had pieces missing on the inside tread.
I have been lowered on Tein Flex Z for about a month and have not gotten an alignment yet. The rear wheels don't have an excessive amount of camber so I was wondering if anyone could tell me what happened?
soccerk18 is offline   Reply With Quote
Old 03-06-2016, 08:48 AM   #2
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
This is most likely a sign of camber wear possibly toe wear, not under or over-inflation. Since the tire was previously on the same side of the car, you have too much negative camber (tire leaning in towards car). When you lower the car, the wheels generally will push towards negative camber, thus, you should generally get an alignment after suspension changes such as yours. Hope this helps.
Just for reference, it is sometimes hard to visually distinguish between say -1 degree camber and -3 to 4 degree camber. You can usually download free apps for your phone that you hold up flush with the wheel to gauge camber angle.
n8dog11914 is offline   Reply With Quote
The Following User Says Thank You to n8dog11914 For This Useful Post:
BRZtoni (03-06-2016)
Old 03-06-2016, 08:52 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What he said.
Old 03-06-2016, 09:20 AM   #4
stevemp5
Drives: scion fr-s
This is why alignment is important
stevemp5 is offline   Reply With Quote
The Following User Says Thank You to stevemp5 For This Useful Post:
slicktop (03-09-2016)
Old 03-06-2016, 09:40 AM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Looks like toe wear to me.
jawn is offline   Reply With Quote
The Following 3 Users Say Thank You to jawn For This Useful Post:
Bobby@Forged (03-09-2016), DocWalt (03-09-2016), Ultramaroon (03-09-2016)
Old 03-06-2016, 09:57 AM   #6
soccerk18
soccerk18's Avatar
Thanks for the quick response! I just measured the rear camber and I have about -3 on both sides. Would that be enough to do that or is it more toe wear?
Old 03-06-2016, 10:17 AM   #7
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
rear toe needs to be done on a alignment rack prior to aligning the front adjustments or she will crab walk.
tire wear can be minimized when running higher negative camber by setting the toe to zero on the rear.
zero toe in the front will make a car 'busy' or twitchy at speed...
thomasmryan is offline   Reply With Quote
Old 03-06-2016, 04:37 PM   #8
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Originally Posted by soccerk18 View Post
. . .I was wondering if anyone could tell me what happened?
Certainly not me, but I'd be rather upset. Excessive wear is one thing, but chunks of tread flying off the tire seems to me like quite another. I'd be real happy if someone would inform me that such disintegration is normal in out-of-alignment tires, but. I have never in my life seen that kind of loss of integrity, and, worn or defective, why in Hades didn't the tire techs who worked on your car point this out to you? Isn't this situation going to be dangerous a few miles down the road?
Your excellent photos show the same thing beginning to happen on the outboard edge of this tire as well. Are any other tires wearing the same way?
Maybe I'm ignorant, but I'd be jumping up and down at the mfr of this tire, wanting to know what it is about the tread compound that's causing it to behave like hard candy under a hammer.
(I think this is my first post that makes my signature quip a falsehood!)
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 03-06-2016, 04:45 PM   #9
gravitylover
That tire is just plain worn out. Too much toe, a couple of degrees too much camber and hard running with a tight suspension on warm pavement. How many miles on the tires?
Old 03-06-2016, 06:16 PM   #10
ryoma
ryoma's Avatar
the only time I have seen chunks of tire ripped off the tread was at a track day on a 5.0 mustang with stock tires. if that happened to you under normal driving, I have to say that it is definitely not safe lol
Old 03-07-2016, 12:33 AM   #11
Poodles
Drives: 2015 Series.Blue
Alignment is definitely off. Tire is trash as it's below the wear markers, which is the reason I know the alignment is off as that the outside wear marker hasn't been worn down to.
Now, chunking like that is usually overheating a street tire. Seen it happen on track cars with street tires.
Old 03-07-2016, 02:50 AM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
I take it you never been to an autox or track day eh?
3 problems that made it like that.
Too much camber and toe in are one. The second is daily driving. Also that tire is pretty much down to the ware bars. Third, heat.
Having all those three in the mix combine with some "sporty" driving habits equals that.
Old 03-07-2016, 07:54 AM   #13
extrashaky
Drives: 2014 BRZ Limited
I just got my tires rotated yesterday...
You wasted your money on a rotation. There was no point. Those tires need to be replaced instead. Whoever took your money to rotate them without pointing this out saw you as a sucker.
Get tires, get the car on an alignment rack, send those tires to Juarez to fuel a brick factory.
The Following User Says Thank You to extrashaky For This Useful Post:
Mr.ac (03-09-2016)
Old 03-07-2016, 11:52 AM   #14
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Whoever rotated your tires is a crook. They should have informed you of this problem.
Those look like the stock Primacy tires right?
One of our locals used his old Primacy for a couple autocross sessions, and he had whole treadblocks missing.
I assume it's because those tires aren't designed to be pushed that way.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
The Following User Says Thank You to HeadBanger For This Useful Post:
Cole (03-07-2016)
Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 62 04-15-2014 02:26 PM
WTT: My FR-S black dash trim pieces for your BRZ silver dash trim pieces. Tim_Asphalt_FRS Interior Parts (Incl. Lighting) 1 05-13-2013 06:25 PM
Humm Coming From Right Rear Tire Well While Car iIs Parked In The Garage davesrave BRZ First-Gen (2012+) — General Topics 2 05-09-2013 08:06 PM
WTT: BRZ(mine) trim pieces for FRS(yours) trim pieces Flat Black VW Interior Parts (Incl. Lighting) 14 07-27-2012 10:01 PM
