Drives: 2014 Scion FR-S Monogram Series
Need immediate help with wheel fitment problems
So I just got some x9.5 wheels wide, I'm on airlift performance bags. My wheels are rubbing my bag, how does everyone else run wide wheels with bags? I bought 8mm spacers to give it some clearance but they're telling me I need extended lug studs to fit on but I can't see how that'll affect it because I've run 7.5 wide wheels with 2 inch adapters before perfectly fine. Please help me figure this out ASAP because I can't really drive!
2014 Monogram Fr-s | Straight piped | Bayson R Wing | Enkei Nt03+M | Valenti CR tail lights | Greddy CAI | HT Auto Lip | STI side skirts | | Sponsored by Inspire_USA | {AIRLIFT suspension}[SIGPIC]
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Panda Trueno
Drives: No twin now.
What offset wheels?
Drives: Asphalt 2014 FRS
Give us your full wheel/tire specs and you'll get a lot more accurate information. Technically you shouldn't run wheel spacers bigger than 3mm on stock studs , but you can always go with bolt on ones.
| The Following User Says Thank You to austin_ellas For This Useful Post: | go_a_way1 (02-29-2016) |
Drives: FRS
wheel offset, width, and tire size determine fitment. not just wheel width by itself.
Drives: 2013 satin white brz limited
Ill respond to this thread how I respond to my coworkers. Poor planning on your behalf does not constitute a emergency or immediate help on my part :P. Jokes aside your alignment information may be of help here as well.
| The Following User Says Thank You to jasonojordan For This Useful Post: | go_a_way1 (02-29-2016) |
Spacer and adapter different. You need spacers, 8mm sounds like it should still fit. I read one you need lug stud diameter worth of engagement minimum. Anything over that is gravy
+20 offset wheels, and I switched to a 5mm spacer hub centric so hopefully that will work. I'm just worried my bag is going to pop and my tires will be ruined within two months. Thanks for all the feedback.
Ok I'm back, I bought camber bolts and am running them now and the problem of rubbing seems to be fixed. There's now a noise coming from my front left wheel sounding like you're running your nails through a comb or like nylon cracking. Any ideas?
#10 |
Tire rubbing fender liner?
| Wheel fitment help. | sskillzz12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-28-2015 12:49 PM |
| Wheel fitment | odessitik | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 09-30-2014 08:39 PM |
| Shiny looking steering wheel problems... | PrinzJ | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 09-21-2012 10:08 AM |
| Rota Wheel Fitment and Where to buy | CharlieChaos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-21-2012 04:30 PM |
| Wheel fitment | sfwg | BRZ First-Gen (2012+) — General Topics | 6 | 10-28-2011 06:33 PM |
