Old 02-28-2016, 05:22 PM   #1
FRSure
Drives: Toyota
Bumper Issue
Hey guys, just a question.
After installing my winjet headlight and reinstalling my bumper..
There is an issue.
There are gaps on my bumper. Although I don't mind it, I am wondering if there is going to be problems such as water getting inside the bumper?
FRSure is offline   Reply With Quote
Old 02-28-2016, 06:10 PM   #2
humfrz
I don't think water getting in there is going to be a problem.
However, it appears that the bumper is not seated properly.
I'd suggest you try to push it in to see if the clips would click.
If not, you may consider taking it off and re-attaching the bumper.
humfrz
Old 02-28-2016, 06:11 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That happens repeatedly when the bumper is put on in a hurry, water isn't an issue however that gap may be annoying. It helps if you screw down that top area first near the radiator with the pop clips and 10 mm bolts before the fender and undertray. Then you pull on the fender side to get it to slide into the headlight grooves.
Old 02-29-2016, 01:00 AM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Maybe this might help.
http://www.ft86club.com/forums/showthread.php?t=86358
Sigh-on-Rice is offline   Reply With Quote
FRS Bumper alignment issue, help please Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2015 02:27 PM
10 series owners! Removing the front bumper. Is there an issue? hahaman86 Cosmetic Modification (Interior/Exterior/Lighting) 9 09-28-2014 10:26 PM
BRZ front bumper fitment issue Thongpocket Cosmetic Modification (Interior/Exterior/Lighting) 0 10-21-2013 02:23 PM
Rear fog light bumper issue Sniper2606 Cosmetic Modification (Interior/Exterior/Lighting) 3 09-27-2013 04:15 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
