Old 02-25-2016, 04:29 PM   #1
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Improving Shifter Feel
Hello everyone!
I've been looking for the past week on how exactly I can improve the shifter feel with this transmission. As some of u may know I have had my trans replaced under warranty just under 1000 miles ago. This is a brand new transmission and I'm still getting the typical super notchy 2nd and 3rd gear shifts not including the grinding feel that makes you cringe in 2nd and 4th.
I've looked around the forum and have considered the following to improve the feel of shifting;
Whiteline positive shift kit?
Rear shifter bushing? - I have a perrin one that I never installed.
Shifter assembly? - TRD/Kartboy
Transmission bushing?
I had motul gear 300 fluid in my last transmission and started having trans problem not even 4000 miles later resulting into getting a whole new trans. I am not blaming it on the motul but I did hear an increase in the TOB rattle with this fluid as well as becoming harder to shift when the trans is cold.
Any tips/tricks/ advice other people have when tackling the shifting feel?
Instagram: trevor.parque
Old 02-25-2016, 04:31 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Motul 300 improved everything for me? That sounds like the exact opposite of what happened when I made the swap.
The Following User Says Thank You to Summerwolf For This Useful Post:
DustinS (02-25-2016)
Old 02-25-2016, 04:33 PM   #3
MisterSheep
Killed Scion
What exactly improved with the fluid change?
Old 02-25-2016, 04:37 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I would say get a TRD short throw and a better clutch because racecar?
MrFisty (02-26-2016)
Old 02-25-2016, 04:38 PM   #5
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I had the same results as @Summerwolf. Noticeable gains over stock fluid. Been going good for 20,xxx+ miles.
DustinS is offline   Reply With Quote
Old 02-25-2016, 04:40 PM   #6
FirestormFlex
Drives: 2015 Turbo FR-S
Motul 300 gear oil and a heavy shift knob made everything feel great for me.
FirestormFlex is offline   Reply With Quote
Old 02-25-2016, 04:44 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
General trans noise went down. Smoother shifts, less clunky, and the cold "warm up" clunkiness is almost completely gone.
When I swapped fluids I didn't think it would do much, but....damn.
Old 02-25-2016, 04:46 PM   #8
_gt86_user
Inactive
Drives: .
Motul 300
Kartboy SS + bushing
Whiteline trans mount
Made it feel more precise in gear changes still rough when cold but goes away, I would like to try a heavy shift knob as well just to see what difference it makes, OEM knob seems to work great over the others I have tried. No rattles with this setup at all.
_gt86_user is offline   Reply With Quote
Old 02-25-2016, 04:50 PM   #9
MisterSheep
Killed Scion
I changed fluid on my previous transmission to motul gear 300 and 4000 miles later I gave the dealership my car to have it looked over.
I was experienced an increase in trans whine as well as a TOB rattle, with notchiness being severely worse. They replaced the transmission and replaced my TOB.
I seem to have had the complete opposite compared to the benefits you had by switching.
Old 02-25-2016, 04:53 PM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
Sorry, had to.
I put the motul in my rear diff too. The factory fill was gross. Changed it again after 10K and the motul looked good, refilled it with motul. IDK what to tell you, but I'm betting your tranny had issues prior to the fluid swap.
Old 02-25-2016, 04:55 PM   #11
MisterSheep
Killed Scion
Sorry, had to.
Maybe it did.. But unfortunately I experienced them right after the fluid swap.. I would possibly consider doing the change again if it will really help. But at this time I'm skeptical.
Summerwolf (02-25-2016)
Old 02-25-2016, 04:57 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Honestly, I would be too after your experience. I just don't see anything else with the same consistent view.
Old 02-25-2016, 05:14 PM   #13
DAEMANO
Time Traveller
Originally Posted by _gt86_user View Post
Motul 300
Weighted shift knobs make a huge difference in smoothness. Raceseng seemed to get it just right with the 600g Slammer.
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
FirestormFlex (02-25-2016), johan (02-26-2016), _gt86_user (02-25-2016)
Old 02-25-2016, 05:26 PM   #14
nisti
nisti's Avatar
Drives: BRZ & XV
Weighted Shift Knob
Rear Shifter Bushing
Mtec transmission springs
nisti is offline   Reply With Quote
The Following User Says Thank You to nisti For This Useful Post:
MisterSheep (02-25-2016)
turbo - why improving LOW-end torque mdm Other Vehicles & General Automotive Discussions 23 02-22-2016 09:17 AM
Improving at Buttonwillow with 86 Cup - shaving a second off my personal best mav1178 Tracking / Autocross / HPDE / Drifting 0 06-30-2015 01:03 PM
A discussion on improving ride quality RYU Suspension | Chassis | Brakes -- Sponsored by 949 Racing 305 06-10-2015 07:55 AM
Improving Steering Feel sittinSideways Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-18-2014 07:52 PM
Short-shifter feel empower-auto Cosmetic Modification (Interior/Exterior/Lighting) 16 11-16-2012 12:13 PM
