Old 02-22-2016, 05:46 PM   #1
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Is it bad form for my heel to slide when using the clutch?
So this is my first car, and thus first time ever driving a manual transmission. I've been trying to get rid of bad newbie habits (most recent one off the list: resting my hand on the gear shift).
Now I'm wondering, is it bad form for me to be sliding my heel when I use the clutch? When I'm depressing it, I notice my heel will slide forward a bit as I get to the last inch or so of motion from the pedal. Then it slides back a bit as I disengage.
I never noticed this until I switched to the "Kagu 3D Maxpider" floor mats, because theres a ridge that happens to catch my heel after I slide forward. So now sliding back is a bit more annoying.
If this is a bad habit, how do I correct it? Is my seating position off? Do I needa get used to using my toe instead of the ball of my feet to engage the pedal?
If its not a bad habit, I'm just gonna get some black epoxy to fill in the ridge on my mats.
EDIT: Pic of floor mat to demonstrate what I mean by the ridge:
PandaSPUR is offline   Reply With Quote
Old 02-22-2016, 06:01 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Shoulda got WeatherTechs lol
Are you hovering over the clutch while you drive? If you cant fully engage the clutch I would probably scoot forward a click
PandaSPUR (02-23-2016)
Old 02-22-2016, 06:53 PM   #3
PandaSPUR
PandaSPUR's Avatar
I had weathertechs, switched to these cause I like how they look.
And nah when I'm driving my foot is on the dead pedal.
I'll try scooting forward a click or two but im already far forward enough that my knees are still bent at full engagement, so I'm not sure if it'll help much.
EDIT: Maybe I should try the clutch pedal adjustment DIYs on the site? I think my main issue is that the pedal comes back up too far.
Old 02-22-2016, 07:04 PM   #4
Don't sweat it. As long as you are pushing the clutch all the way down there is no right or wrong foot placement. If your foot is stable on the pedal then all is good no matter what part you are using.
Now I hand it over to all the guys that will say you have to have precisely a 22.8 degree angle at apex which must be increased by exactly 1.5835 degrees per millimeter until you hit the bottom or you are doing it wrong.
Chrisgalactic (02-24-2016), PandaSPUR (02-23-2016)
Old 02-22-2016, 07:06 PM   #5
finch1750
finch1750's Avatar
Maybe you are too close then. My leg is basically fully extended Pushing in the clutch/gas (on my MT cars at least)
Though the DIY does help a great deal. I hate the MT on these cars from factory actually. not that it cant be easily fixed
Old 02-22-2016, 08:23 PM   #6
dvasqu01
dvasqu01's Avatar
Drives: Scion FRS Whiteout
Then you have to be sure to know the six trig functions sin cos sec csc tan cot of 22.8
Yes I'll give you the rice noodle😘
dvasqu01 is offline   Reply With Quote
The Following User Says Thank You to dvasqu01 For This Useful Post:
Tcoat (02-22-2016)
Old 02-22-2016, 08:41 PM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I'm suggesting given the type of curve described by the ball of the foot one should be using hyperbolic functions here.
Tcoat (02-22-2016)
Old 02-22-2016, 08:43 PM   #8
finch1750
finch1750's Avatar
Can you tell me how to do this on my Ti-82?
Old 02-22-2016, 08:49 PM   #9
Captain Snooze
Drives: Red Herring
Sorry, it's HP or go home.
RPN for the win!!
Tcoat (02-22-2016)
Old 02-22-2016, 08:55 PM   #10
Venom1506
Drives: 16 Ultramarine FRS
I'm not here to tell anyone how to drive but you might want to reconsider your driving position if you need to fully extend your leg to push in the clutch pedal.
In the event of a front end collision, if you have your left foot mashed on the clutch, you're going to do some serious damage to every bone starting from your foot straight to your hip.
Venom1506 is offline   Reply With Quote
The Following User Says Thank You to Venom1506 For This Useful Post:
Old 02-22-2016, 09:00 PM   #11
finch1750
finch1750's Avatar
thats to get it to the floor, and there is still a slight bend in my knee. I dont need to put it all the way to the floor though I guess I probably would have it slammed down in that situation. not sure I'll change it as its how im the most comfortable but good food for thought. If I was in a wreck that bad though not sure it would make much difference either way
Tcoat (02-22-2016)
Old 02-22-2016, 09:51 PM   #12
dvasqu01
dvasqu01's Avatar
Well that's depending what your trying to find I was assuming he will want to find the Distances between the floor to the top of the pedal and the distance from the start point of the pedal to the floor 😜
Old 02-23-2016, 01:41 AM   #13
PandaSPUR
PandaSPUR's Avatar
Good to know I'm not doing anything wrong to the car mechanically at least, thanks. Still gonna try to fix it though because I feel like it screws up my reaction time and having to unstick my heel just distracts me, even if for just a second.
Hmm. I guess I'll spend a few hours this weekend tweaking my seat and adjusting the pedal till I get to a good spot.
To the rest of the posts in this thread. . . lmao, you guys never fail to entertain.
Old 02-23-2016, 03:31 AM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
hm, E(x,t) = EmSin(0.7x-0.89t)
B(x,t) = BmSin(0.7x-0.89t)
Now, idk if i can equate the accelration of the ball of your foot towards the clutch pedal to the time it takes to disengage the clutch...id need more time to set that up lol.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
finch1750 (02-23-2016), ScoobsMcGee (02-23-2016)
>>> 3 New Lightweight Flow Form Wheels <<< 720 FORM Compilation Anorexic 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 346 06-11-2019 07:27 PM
DIY Keyport slide replacement key post_break DIY (Do-It-Yourself) Guides 9 09-22-2015 09:41 PM
Slip'n Slide! BuBlake Scion FR-S / Toyota 86 GT86 General Forum 45 10-03-2012 07:55 AM
Any new owners try an E-Brake slide yet? Space Boy Matt Scion FR-S / Toyota 86 GT86 General Forum 4 06-12-2012 03:14 AM
