Old 02-18-2016, 01:34 AM   #1
Meanderchap
Drives: Scion FR-S Whiteout 6MT
OEM vs. Whiteline camber bolts
I dropped my car on Eibach Prokit springs a few weeks ago and I'm about to get an alignment and camber bolts installed. Not sure if I should get the OEM crash bolts (14 mm and fits on bottom hole, right?) or Whiteline/SPC (16 mm and fits on top hole, right?). I'm not tracking the car. Also, if I go OEM does it matter if I get the Subaru part for an FR-S? Thanks.
Meanderchap is offline   Reply With Quote
Old 02-18-2016, 02:51 AM   #2
swarb
Old 02-18-2016, 03:42 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
How much camber do you want/need?
OEM: 14mm bolt for top hole. Will get you about -1
Whiteline: 16mm upper will get you -1.5 or so
SPC: 14mm for bottom hole. will get about -1.5 (bonus: the bottom bolt you removed is the OEM crash bolt. You can now move that to the upper slot and get -2 to -2.5 degrees when using it with the SPC)
Subaru or Toyota doesnt matter for OEM. Get whatever is cheaper
Old 02-18-2016, 03:26 PM   #4
icybrzzz
Drives: 2015 Scion frz
If I have both Whiteline and SPC, does that mean i will be able to get -2 to -2.5 degrees of camber as well then? Or more now that the whiteline is up top?
Ordered the whiteline one but i'm not installing it till spring, if thats the case I'll order an SPC one for some more camber on stock suspension
icybrzzz is offline   Reply With Quote
Old 02-18-2016, 03:34 PM   #5
finch1750
finch1750's Avatar
it is my understanding that running 2 eccentric bolts like that increase the risk of slipping. i think someone on here has run it before but not sure what their numbers were
Old 02-18-2016, 03:37 PM   #6
icybrzzz
I am better off just running the whiteline bolt then?
If thats the case I'll just do that and when I get coilovers I'll get the SPC bolts and use the stock ones up top.
Old 02-18-2016, 03:44 PM   #7
finch1750
finch1750's Avatar
that would be my reccomendation. im not a pro but I did a lot lf research to do things right for once on this build. That sounds good on the couls, just make sure the hole is slotted that put the spc in
Old 02-19-2016, 01:16 PM   #8
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
http://lmgtfy.com/?q=crash+bolts+site%3Aft86club.com
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
WTB: SPC or Whiteline Camber Bolts djrbash Want-To-Buy Requests 2 02-12-2016 11:42 AM
FS: Whiteline Camber Bolts SilverBullet86Z Brakes, Suspension, Chassis 2 10-11-2015 08:52 PM
Whiteline Camber Bolts NEW jack43 Brakes, Suspension, Chassis 3 03-21-2014 08:47 AM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
