Old 02-15-2016, 10:16 AM   #1
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
Is this normal?
This is motul 300 manual transmission fluid after about 25k miles.
ハチロク is offline   Reply With Quote
Old 02-15-2016, 10:16 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
broken image, and @MisterSheep
Old 02-15-2016, 10:22 AM   #3
ハチロク
ハチロク's Avatar
Think it's fixed. Thanks.
Old 02-15-2016, 10:39 AM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Uhm.. It's hard to tell as I did not get to see the fluid once my trans was drained. I actually just got back from warranty work for getting my whole transmission replaced. I can't help you out here bud :/ but I would like to know the outcome/ answers some people more knowledgeable will come up with
Instagram: trevor.parque
Old 02-16-2016, 07:07 PM   #5
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Have you ever driven through deep water? IMO, it looks like the oil has water in it.
https://www.google.com/search?biw=19...41.C4N85hIKvVo
sly is offline   Reply With Quote
Old 02-16-2016, 07:24 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah but is it not a sealed system or the fluid would have leaked out
Old 02-16-2016, 07:31 PM   #7
ハチロク
ハチロク's Avatar
Yeah it should be a sealed system and I didn't see any leaks.
Old 02-16-2016, 08:11 PM   #8
stevesnj
stevesnj's Avatar
Got to be condensation or something of the sort. There are bubbles on the surface. Looks like water to me. Unless there was water in the pan before you emptied the oil into it. Could be a clogged or malfunctioning breather valve.
My 2016 Build thread
Old 02-16-2016, 08:16 PM   #9
ハチロク
ハチロク's Avatar
The pan want 100% clean when i used it but there wasn't much in it when I used it. When I emptied the fluid it poured out rather quickly. Might explain the bubbles. What should it look like after 25k miles?
Old 02-16-2016, 08:30 PM   #10
stevesnj
stevesnj's Avatar
Not like this I would think. Where in Jersey you at?
Old 02-17-2016, 01:27 AM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Looks like it was contaminated with water. There's a breather valve that allows for hot air expansion but checks against contraction.
It's supposed to be almost as clear as the day it was filled. That's definitely a problem.
edit: what @stevesnj said.
Old 02-17-2016, 03:34 AM   #12
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yeah, definitely not supposed to look like that. The last time my transmission fluid looked like that, it was in my old Subaru Outback. I drove through a flooded road that was almost 2 feet deep because #Subaru. The next day after work, my car suddenly refused to make any turns without the whole drivetrain binding up. Drained diff and transmission fluid and that was what it looked like, lol.
As others have said, your fluid should basically look identical to new fluid.
Stang70Fastback is offline   Reply With Quote
Old 02-17-2016, 09:36 AM   #13
Nickosport
Drives: 2015 WRB BRZ Premium
Yeah, that's not normal. I agree it looks contaminated with water. It also looks to have a fair amount of metal in it.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 02-17-2016, 09:38 AM   #14
ハチロク
ハチロク's Avatar
This sounds like bad news... What should I do about it?
Is this normal? scottxnizzle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 03-10-2015 12:26 PM
Is this normal in the OFT?? benlaz88 Software Tuning 4 12-04-2014 09:23 PM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 03:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 02:54 AM
