Old 01-28-2015, 01:11 PM   #1
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
Is this normal?
Is it normal that ever since I installed my KWV3 coilovers the ride quality has become more bumpier? lol I haven't played with the settings yet (rebound, bump)
Compared to my stock suspension, I don't remember it being that bumpy. You can say I feel the road more.
Is this normal?
scottxnizzle is offline   Reply With Quote
Old 01-28-2015, 01:54 PM   #2
Racecomp Engineering
You need to adjust the settings. KW V3s are double adjustable for damping (separate rebound and compression) so you have a lot of control. You just need to use it and use it right.
Contact your suspension vendor for tips or dig around for the settings we posted on here.
When set up correctly they should ride as good or better than stock.
- Andy
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
AZP Installs (02-02-2015), CSG Mike (02-03-2015), JDKane527 (02-04-2015), scottxnizzle (01-28-2015)
Old 01-29-2015, 04:41 PM   #3
scottxnizzle
Drives: WRB BRZ
- Andy
I am also running spacers (20mm front, 25mm rear) on stock rims/tires. I will buying some 18x9.5, all around wheels soon. Would the spacers on stock wheels/tires make a difference in quality? Would bigger wheels/tires help in the ride quality?
Now that I think about it, the roads I drive on aren't really that great lol but I do notice more of a bumpier ride.
Old 01-29-2015, 04:46 PM   #4
18x9.5 wheels are too wide IMO and will have a negative impact on ride and handling. Too heavy. Everybody is doing it though.
A more reasonably sized and lighter wheel will be better.
Spacers will have a small negative impact on ride quality...they add a little unsprung weight which does not help. But the effect could be minor.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
mad_sb (02-05-2015)
Old 01-29-2015, 11:16 PM   #5
To the OP:
Try these settings:
FRONT REBOUND: 12
FRONT COMPRESSION 13
REAR REBOUND : 14
REAR COMPRESSION : 9
*** ALL OF THESE SETTINGS ARE FROM FULL STIFF ******
So adjust the adjusters to FULL STIFF( CLOCKWISE ) then back it off these numbers of clicks.
Myles
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
D_Thissen (02-02-2015), JDKane527 (02-04-2015), JohnJuan (01-30-2015), PandaBRZ (01-29-2015), scottxnizzle (01-30-2015), wparsons (01-30-2015)
Old 01-30-2015, 11:13 AM   #6
scottxnizzle
Drives: WRB BRZ
To the OP:
Try these settings:
FRONT REBOUND: 12
REAR REBOUND : 14
Myles
Thank you! ill try these settings whenever I get a chance to adjust them. Where did you get them, if you don't mind me asking?
Old 02-02-2015, 08:17 AM   #7
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
First question is who setup the coilovers for you?
Was a proper professional alignment done?
Was the ride height setup?
Preload?
Corner Balanced?
What other modifications are done to the suspension? (Sways, LCAs, etc)
On our Project BRZ for AZP Installs, we had to raise the KWv3s up quite a bit in order to get better handling on track. When they were set too low, the ride and handling was terrible.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 02-03-2015, 09:08 PM   #8
Those are my settings from driving on v3's spring of 2013.
Myles
Old 02-04-2015, 04:06 AM   #9
3essess
Drives: frs
How low are you...bump stops ARE bumpy...mine are at almost max height and it is way smoother than when i was dropped on the low end of KWs specs. Also, if you are on the stiffer end of bump or rebound, the ride will be a lot harsher is what I've found.
3essess is offline   Reply With Quote
Old 02-04-2015, 02:02 PM   #10
scottxnizzle
Drives: WRB BRZ
fairly low? lol one finger gap? haven't actually came around to measuring it. I also haven't came around to adjusting the settings. Im assuming the settings are stock except the height.
Old 02-12-2015, 03:55 AM   #11
3essess
Drives: frs
I have 17x9 with 245x40, 24.7" diameter. I had a ~1 finger gap and that is on the low end where the ride will be pretty bump, especially on sharp edged bumps. But then again, I have the "soft" KWV3 coilovers which are too soft for my purposes (autox).
Old 02-12-2015, 11:36 AM   #12
JGalp
Drives: 2015 CWP BRZ Limited
- Andy
What are more reasonably sized wheels? and which ones for lighter weight?
17x9? 18x8.5? any wheels you can throw out there for all of us to do some research on?! thanks!
JGalp is offline   Reply With Quote
The Following User Says Thank You to JGalp For This Useful Post:
Scottemad123 (02-12-2015)
Old 02-12-2015, 01:31 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The stock wheel size can come in pretty light aftermarket varients.
If you want to get ballsy with your wallet and weight savings, try to find magnesium wheels.
Old 02-12-2015, 02:05 PM   #14
We ran 18x8 +38 offset on our very track focused car. BBS CH. Very pretty and strong. There are lighter wheels though.
9 inch wide is okay, 8.5 is getting better. Enkei, Wedsport, Volk, Rays, BBS, etc. all good brands.
- Andy
Is this normal? Dino451 Scion FR-S / Toyota 86 GT86 General Forum 20 10-11-2013 12:56 AM
Is this normal? BlackyRose Engine, Exhaust, Transmission 8 10-04-2013 11:54 AM
is it normal? Minovsky Issues | Warranty | Recalls / TSB 5 04-23-2013 11:56 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 02:54 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) — General Topics 10 10-12-2012 02:54 PM
