Old 02-15-2016, 05:04 AM   #1
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Changing Tuning Software -BRZedit to Ecutek
Hey guys,
Looking at changing my tuning software. I want flex fuel and other features only offered through ecutek.
Problem is I have a tune by BRZedit on my ECU. Do I need to flash back to stock?
Or could I use an OFT without flashing back to stock?
Thanks in advance!
Ps. Sorry if this has been covered. Search function doesn't work on my phone
COO86L is offline   Reply With Quote
Old 02-15-2016, 05:32 AM   #2
steve99
Originally Posted by COO86L View Post
Hey guys,
Thanks in advance!
You wont be able to use an oft, as an oft is married to a single car at a time.
You may be able to use tactix\ecuflash to overwrite the brzedit tune with a stock tune.
Im not 100% on how brzedit locks ecu, its almost certian it read locks ecu to tune cannot be read, but it may also change seed keys which means you cannot read or write.
the safest option would be to get whoever used brzedit to tune it to write a stock rom back to ecu
FRS Justin (02-15-2016)
Old 02-15-2016, 07:02 AM   #3
COO86L
COO86L's Avatar
So if the tuner sent me my original Rom, I could flash it back using BRZedit? And then go from there with ecutek?
Old 02-15-2016, 09:27 PM   #4
steve99
sorry im not sure how brzedit locking works or even if tuner guy locked tune.
If you have cable you could try flashing stock rom yourself.
otherwise ask the tuner guy.
stock roms are not uniquie they just need to be same calibration id
Old 02-16-2016, 01:57 AM   #5
COO86L
COO86L's Avatar
From trying to read using openecu, I believe it is locked, at least only to brzEdit. The tuner has previously advised he can send me a tune which I'd need a license to write to the ECU. I'm just curious as to if I flash with a stock tune using the brzEdit software, would that release any read/write locks on the ECU and would it be likely that I'd need the original he's removed using brzEdit?
Any help from anyone that knows will be much appreciated.
Old 02-16-2016, 02:10 AM   #6
steve99
I have posted up most of the stock roms at the end of the Tactix post linked below.
you will ned to know your calibration id like ZA1JA01G or whatever.
I know brzedit read locks ecu but im not sure if its write locks as well by changing seed keys like ecutek.
If you have a tactrix adapter and ecuflash software (free) then you might as well try and write a stock rom to your car with that. You should be able to read just the rom calid with a scantool or android torque app as this is a standard obd call and does not require read write access to rom.
Old 02-16-2016, 02:19 AM   #7
COO86L
COO86L's Avatar
From my very limited knowledge, that is actually the Calibration ID of my car "ZA1JA01G" which I have downloaded. Tried to write with ecuflash but it gathers some data (Calibration ID, Vin, etc) then fails. I'll have to post up exact logs when I get home from work.
Old 02-16-2016, 02:32 AM   #8
steve99
Hmm sound like its locked for write as well.
you can access vin and calid and log ecu parameters even if its locked. Its when you actually want to put eu in program mode to read\write rom that the ecu lock comes into play
I gather the tuner is a fair distance away ?
it looks like its a visit to tuner that flashed it or you need to confirm 100% that he can send you stock brz edit rom that you wwill need to flash with brzedit .
Brz edit is going to cost you about 100 usa dollars for the cheapest licienced version, you need to confirm with tuner guy that this veersion is good enough and you dont neeed the tuner veersion which is much dearer to unlock your car
Old 02-16-2016, 03:11 AM   #9
COO86L
COO86L's Avatar
That was my thought also. All indicators point to it being locked.
I'd happily go and visit or do whatever is needed to return it to stock so I can pursue different tuning options but I haven't heard back from him for a few days. Unsure if he has grown uncooperative.
At this stage I might just wait until he gets back to me or start annoying him by phone soon.
Old 02-16-2016, 03:26 AM   #10
steve99
their is a brzedit tuner in brisbane , bit of a drive coyote tuning thgey arexon facebook
or matt from throttlehappy tuning think he is northern nsw although he travels a lot also on facebook unless they are they guys who did the tune
Old 02-16-2016, 03:13 PM   #11
ztan
Drives: Toyota 86
Hey guys,
Thanks in advance!
Once you get rid of the locked tune, let me know if you want flexfuel without EcuTek. I've got A01G flex fuel working well using RomRaider/Tactrix and am just up the road from you.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
steve99 (02-16-2016)
Old 02-16-2016, 07:29 PM   #12
COO86L
COO86L's Avatar
[11:31:11.977] CALID : ZA1JA01G
[11:31:11.979] CVN : CBCCA8EC
[11:31:11.986] VIN : JF1ZN6K81GG032993
[11:31:11.986] starting programming session...
[11:31:11.988] turning off DTCs...
[11:31:13.002] turning off unnecessary communications...
[11:31:13.509] unlocking ECU...
[11:31:13.509] Requesting Seed...
[11:31:13.509] Sending Key...
[11:31:13.509] no response to security access request
[11:31:13.509] interface close
This is what comes up when I try and read with ecuflash. Any pointers?
Old 02-16-2016, 08:58 PM   #13
steve99
yep its locked
Old 02-16-2016, 09:07 PM   #14
COO86L
COO86L's Avatar
Sadness.
EcuTek UK have said they are happy to assist in unlocking it for me. May just end up going that way I think.
Thanks heaps for all your help though
Ecutek tuning software questions for newbie keonigt Software Tuning 2 05-28-2015 03:59 AM
EcuTek Announce FT86 Retail Tuning Software EcuTek Software Tuning 326 05-17-2015 01:31 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
brzEdit Software Updates & Lower Pricing brzEdit Software Tuning 24 10-01-2013 09:21 PM
