Old 02-13-2016, 03:27 PM   #1
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
Question Stiffer springs on Fortunes Auto 500s
So I bought a set of fortunes off another guy, and they came in the 6k/7k setup which feels too soft for me. A little back story, I previously had FA500s before I went air about 2 years ago, with 8k/7k spring rate and loved it. The current 6k/7k set is almost on full max dampening and I feel that the car feels too floaty still. I'm dropped about 1.5"-2" now. Anyway, would I be able to upgrade to swift springs in 8k/8k without any problems, or would I need it re-valved?
BRZach is offline   Reply With Quote
Old 02-13-2016, 03:37 PM   #2
swarb
You best bet is to contact them directly. Try them softer and see how it works out. If you add spring rate, floaty feeling will turn into bouncy. Make sure they aren't blown and the preload is set correctly.
Old 02-13-2016, 09:22 PM   #3
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
You shouldnt have to get them revalved.
gatorbushmen is offline   Reply With Quote
Old 02-14-2016, 07:36 PM   #4
Jenson May
Drives: Evo
You do not need to revalve for that spring rate change
Regards,
Jenson
Fortune Auto
Jenson May is offline   Reply With Quote
Old 02-14-2016, 10:14 PM   #5
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
Regards,
Jenson
Fortune Auto
Thanks, since youre a rep. of Fortune, can you please tell me which diameter of Swift springs I would need in order to swap?
Old 02-15-2016, 11:55 AM   #6
Jenson May
Drives: Evo
My pleasure, you will need the 60mm ID blue Swift springs.
Old 02-15-2016, 08:35 PM   #7
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
Thank you! Also, would it be recommended to keep the same length spring as the ones already on the suspension? Thanks in advance
Old 02-18-2016, 10:22 PM   #8
Jenson May
Drives: Evo
yes that is recommended
KW V3 Coilovers feel stiffer over time? mkivalex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-20-2015 08:28 AM
Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around??? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 02-20-2014 03:50 AM
Fr-s on Fortune Auto 500s Propaganda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-10-2014 07:33 PM
stock height stiffer springs? vgi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 10-06-2013 11:08 PM
Fortune Auto V4 500s W/ Roller bearings FR-S86 Brakes, Suspension, Chassis 21 02-12-2013 03:30 PM
