Old 02-10-2016, 03:47 AM   #1
shern
Drives: 2015 fr-s
weird noise sound coming around header area
just bought a uel tsudo header i installed it and whenever i floor it i here a clutter type noise what could it be?
shern is offline   Reply With Quote
Old 02-10-2016, 07:23 AM   #2
BRZnut
Drives: BRZ DGM Limited
can you record the noise so people can hear it?
Old 02-10-2016, 08:07 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Remember aftermarket headers use a thinner metal so they make more NVH
Old 02-10-2016, 10:43 AM   #4
shern
Drives: 2015 fr-s
Yeah im gonna work on getting a video for you guys today! thanks
Old 02-10-2016, 10:49 AM   #5
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Tsudo is a low quality knockoff brand. My money is on: you have an exhaust leak.
SpectreRT is offline   Reply With Quote
Old 02-10-2016, 01:57 PM   #6
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
I have an OpenFlash Header and had the same type of noise. For me it was more of a fluttering/leaves rustling type noise. Someone above mentioned the thinner walls of the header which could be it. For me it was a combination of loose nuts/bolts...took several re-tightening and addition of thread locker to make sure it didn't come loose. I think it's good now but at lower RPMs it does make that sound slightly.
Just remember to re-tighten to spec because it can become loose after initial install due to hot/cold temps after running your car.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-10-2016, 01:59 PM   #7
ap5512
ap5512's Avatar
^^ Also, another thing. If it is loose like mine was, your data logger should tell you if you have a something like Open Flash Tablet or something similar because your parameters will be off.
The Following User Says Thank You to ap5512 For This Useful Post:
shern (02-10-2016)
Old 02-10-2016, 04:07 PM   #8
shern
Drives: 2015 fr-s
Thanks for the info man ill make sure to retighten everything to day! and yeah mine does sound like a fluttering the leaves noise! and yes i know tsudo is low quality but i took the risk to see if ill get a good one and it did all the welds look great and the collector looks decent so quality wis ill give it a 8/10
Old 02-10-2016, 04:29 PM   #9
steve99
Drives: FT86
Also check the overpipe or headers is not hitting on chassis or aluminium skid plate
The Following 2 Users Say Thank You to steve99 For This Useful Post:
shern (02-10-2016), Tectoniic (02-12-2016)
Old 02-10-2016, 04:32 PM   #10
shern
Drives: 2015 fr-s
I feel like its the connection between the overripe and the collector ! I used the stock gaskets the connect to the block and i tighten everything really tight but like i said I feel like its the connection to the overripe
Old 02-10-2016, 04:55 PM   #11
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Use an OEM gasket and gasket maker / sealer on both ends. I'm highly betting you're having an issue where the flanges are not flush and its leaking.
The Following User Says Thank You to SpectreRT For This Useful Post:
shern (02-10-2016)
Old 02-10-2016, 05:04 PM   #12
shern
Drives: 2015 fr-s
Yeah man thats what it is I'm gonna look for my stock gasket
if i can't find it ill just go down to toyota and buy one from them
Old 02-11-2016, 10:18 AM   #13
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Just get a new one. Its ~$20. They have a slight crushing to them, so reusing an old one may not help.
Use the RTV Silicon Gasket Maker stuff as well. Thin layer on each side of the gasket. That'll be double sure no more leaks.
shern (02-12-2016)
Old 02-11-2016, 10:55 AM   #14
Jrohit
Jrohit's Avatar
Drives: 2013 FRS 10 Series #2072 (6MT)
If Toyota doesn't have it, Subaru definitely will. Learned from experience.
If anything, I'd be caught dead smiling.
Jrohit is offline   Reply With Quote
The Following User Says Thank You to Jrohit For This Useful Post:
shern (02-12-2016)
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 07:40 PM
Weird Crinkling noise coming from center console fitcious Scion FR-S / Toyota 86 GT86 General Forum 14 03-20-2016 04:56 PM
Weird rattling noise in cabin coming from front left Webster10 Scion FR-S / Toyota 86 GT86 General Forum 36 03-01-2016 04:44 PM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 06:04 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-01-2013 11:42 PM
