Old 02-08-2016, 01:53 PM   #1
Nah
Drives: 2013 Scion Frs 6mt
OFT A/F tuning question
Hello everyone, Quick question for ya.
While using OFT how would I tune closed loop fueling? After installing my perrin 2.5inch catback I noticed some fluctuation in my air to fuel ratios. while cruising I am hitting 14.2 so just a tad rich (expected this). I've read the other threads so just looking for a quick straightforward answer (sorry if this is called spoonfeeding). I do understand how to use romraider and log, any help is appreciated.
Also when doing some wot pulls I have noticed my a/f will go lean 15ish then back down to the correct a/f but still doing 11.6 imo this is a little to rich?
The transition from CL to OL is not as smooth as I would like it and when I dial in the A/f ratios I plan to adjust timing for daily drive-ability.
Any tips are appreciated, really looking for laymen's terms which I am sure could help others like me thanks.
Current modifications:
JDL UEL header
stock op
stock fp
Perrin 2.5 resonated cbe
A01C
Edit: CL compensation A or B? I am assuming B
Edit 2: When flashing back to back adjusting timing or fueling how many miles do you guys recommend until I log at wot for an accurate reading?
Nah is offline   Reply With Quote
Old 02-08-2016, 05:17 PM   #2
phrosty
Catback will not have any effect on AFR. Closed loop should not run rich or lean by anything significant... that's the magic of closed loop. Post a log if you're not sure; sounds like you might be misinterpreting it.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
FRSBRZGT86FAN (02-08-2016)
Old 02-08-2016, 07:07 PM   #3
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
You need to adjust your MAF scale. most of the off the shelf tunes will be rich especially if you have a stock air intake. this is a scale I found that should help, https://docs.google.com/spreadsheets...R3Y/edit#gid=0 My guess is somewhere close to (V97 us Lean stg2)
oldgunfan is offline   Reply With Quote
Old 02-08-2016, 11:47 PM   #4
Nah
I did a quick reflash and logged after 20 miles or so and afr seems pretty close to commanded afr. My main "concern" is the transition from closed loop fueling to open loop is not as smooth as I would like it to be.
when im hitting 11.2 afr at wot I am definitely running rich when the commanded afr is 11.8.
So while using rom raider would I lean out the commanded afr more? I would like the smoothest afr possible to be able to maximize safe power.
Ideally, what is the best commanded afr during open loop while being N/A with boltons to maximize power?
Old 02-09-2016, 12:33 AM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
A quick reflash of what? The same tune? That won't do anything for you.
And you don't need to change your commanded AFR, you need maf scaling and possibly load limits. Go read up on Wayno's "OTS GUIDE TO DIALING IN YOUR TUNE"
New to Tuning... Simple Question cpnslow Software Tuning 21 10-09-2014 12:10 AM
FI tuning question Fear Forced Induction 33 05-30-2014 10:40 PM
Noob question about tuning CamryDS Engine, Exhaust, Transmission 8 06-27-2013 01:29 PM
ECU Tuning Question Ahernandez0909 Engine, Exhaust, Transmission 15 03-24-2013 03:03 AM
DDM Tuning Lighting Question! SMOKETREES Cosmetic Modification (Interior/Exterior/Lighting) 0 09-27-2012 06:55 PM
