| DIY (Do-It-Yourself) Guides For all DIYs. |
Supra Senior Member
Drives: AE86 & BRZ
Tire Stickers
[ame="https://www.youtube.com/watch?v=wnXOVS5Ycow"]Tire Stickers Game Changer - YouTube[/ame]
Material Towel soap Sand paper doesn't really matter the grit just not a heavy grit (optional - brake cleaner or alcohol (acetone works well) cleaner. Instructions: -Clean surface with house hold degreaser, or what you maybe. Acetone works well as well. -Clean the back side of the tire sticker as well. You can use acetone or brake cleaner -Apply the FleXement adhesive to the back side of the decal. I personally went crazy with it. -Firm press the decal on the tire. Note: you can use the lines that comes with every tires to help guild where you want to put them. -Wait 1 hour for cure 24 hours @ room temperature. So, if it is colder wait longer. -Remove the film and show off your decal. Order here:https://www.tirestickers.com IMO they are the most affordable in the market. It works well and looks good. ![]()
Drives: 2013 Firestorm FRS
interesting
Drives: GT86
Know a few people that would be interested. What is the cost?
I like the look of them and even considered it at one point, but their website shows that a set of 4 is around $100. that is definitely way more than I am willing to fork over lol
#6 | |
Drives: scion frs
Great review!
Drives: FRS
make sure to also drive around the block a few times after letting the glue cure. the sidewall will flex as the car drives obviously, and this can (and almost always will) cause some of the adhesive to come undone. not a big deal, but you'll need to redo some corners and whatnot with extra glue.
if you do the temporary ones, these are way cheaper at like 1/4 of the cost for a full set of tires (4) and easy to stick on smooth. but as tirestickers warn you, these really are temporary. mine lasted about a week before they completely lost color. i had the permanent set on my previous wheel/tire setup, and once i got past the initial week of having some of the letters lift up, they really were permanent afterwards. too bad i lost a couple letters in the process lol
#10 |
Drives: 10 Series #974 6m/t
https://tredwear.com/ i would go with these
#11 |
Drives: 2014 BRZ
Thanks for the video! Could you specify which decal height you selected for the tire sticker in the video?
| FS: 4U-GSE stickers, Toyota Emissions stickers and "86" stickers *SOLD OUT* | trueno86power | Interior Parts (Incl. Lighting) | 23 | 07-10-2016 03:07 PM |
| What do you do with the stickers? | Ramster | Off-Topic Lounge [WARNING: NO POLITICS] | 33 | 07-13-2015 11:50 AM |
| GT-86 Stickers | nabil_frs | CANADA | 4 | 03-29-2013 01:14 AM |
| my new stickers | jschendel | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-01-2012 09:46 AM |
| Stickers ! | SCIONMONTREAL | CANADA | 3 | 04-20-2012 01:44 PM |
