Old 02-03-2016, 08:13 AM   #1
els7x5
Drives: Black FR-S
Dump tube sound changable?
I'm running a D3PE turbo and it uses a short dump tube off the wastegate. When I get over 3 psi that opens up and puts out a sound that is somewhat undesirable. Id describe it as a somewhat high pitch wail, what you'd imagine a lot of air through a 1.5in pipe might sound like. Is there a simple way to alter this?
els7x5 is offline   Reply With Quote
Old 02-03-2016, 12:24 PM   #2
kch
Senior Misanthrope
kch's Avatar
You could have it custom fabricated to recirculate the wastegate into the downpipe.
The Following User Says Thank You to kch For This Useful Post:
R2RO (02-03-2016)
Old 02-03-2016, 12:53 PM   #3
els7x5
Drives: Black FR-S
I have heard it will decrease the scream so I can hear the turbo spooling but will also lose hp and I'd like to keep max hp with lowest possible boost in order to keep stress off the engine. I was hoping more for a replacement dump tube or an attachment I guess. Hearing that trill at higher boost would be pretty sweet though!
Old 02-03-2016, 01:00 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Recirculate it. If it's going to cause a loss in power your exhaust is probably too small to begin with. No other way around it really. If you try to muffle the dump tube you're hurting flow, if not worse than recirculating to the downpipe
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
R2RO (02-03-2016), Sportsguy83 (02-03-2016)
Old 02-03-2016, 04:07 PM   #5
els7x5
Drives: Black FR-S
I have the TRD exhaust but just read that you can lose some HP in another forum. I don't want it muffled so much as a different sound though. I can't find anything about doing that though so figuring it might not be a thing.
Old 02-03-2016, 04:36 PM   #6
mrk1
Drives: Sterling BRZ Ltd
As long as a competent individual does the fab work and the its recirc'd in a good place at a good angle you will be just fine. HP loss is extremely minimal it also doesnt sound like your really stretching for the every last HP anyway.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
Sportsguy83 (02-03-2016), Strife26 (11-30-2017)
Old 02-03-2016, 04:38 PM   #7
mrk1
I hope your expectations are realistic.
The Build Thread
Old 02-03-2016, 07:16 PM   #8
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
The only way of changing the sound would be to extend length of the pipe or maybe add a tiny silencer on it which would defeat the purpose of having it by adding more weight to your car and etc, or recirculate it back into the exhaust(BEST OPTION).
I have a JDL Autodesign kit with a Open dump, It doesn't open up till 9 Psi but that puppy screams when its open, I would suggest moving to a bigger spring in your wastegate so you're not always opening it up after giving it gas. You can even get a Electronic boost controller after moving to a bigger psi spring so you can limit the amount of boost you run, but I think the lowest setting on a boost controller is always your spring's rating.
just my 2 cents.
R2RO is offline   Reply With Quote
Old 02-03-2016, 07:49 PM   #9
kch
Senior Misanthrope
kch's Avatar
difference will be minimal. there's a slightly increased chance of boost creep with a recirc (or so I've been told), but it's not a huge deal.
Old 11-30-2017, 09:22 PM   #10
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
"So I've heard." BUT IS IT TRUE?! Screw you internet, lol.
So much information, but so much back and forth info.
I saw the same thing, but I keep seeing more often than not, there aren't huge downsides if done correctly. I'm hoping that's the true true answer.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
FS: TRD Sound Tube its_the_biz Engine, Exhaust, Bolt-Ons 0 12-14-2014 04:46 PM
Dump tube muffler, halp! BRZPDX Forced Induction 4 06-22-2014 09:29 AM
FS OEM sound tube Vlady Engine, Exhaust, Bolt-Ons 0 10-16-2013 07:59 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
