Old 02-02-2016, 09:16 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Tiny oil leak, nothing more.
Hey guys I can't get rid of an oil leak after checking all connections. The leak is at the oil pan and drain fitting. I've dropped the turbo headers and oil pan twice now and to be honest i'm not dropping it a third time.
I'm planning on installing a new, completely different AN fitting but i'm not sure what the thread on the Full Blown oil pans return is.
If you guys have any suggestions or ideas I'm completely open. I rather not replace. The oil leak is super tiny but it does dip time to time on the headers and makes a tiny poof of smoke.
Again the leak is from the return fitting and the oil pan. The picture below is the pan and the fitting i'm talking about is at the very top of the picture.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-02-2016, 11:06 PM   #2
Northwest86
Drives: Velocity Orange 86 GT
Any pipe threads have a sealant like Loctite 567 and not crappy plumbers Teflon tape? It's not a Cam plate leak and definitely at the sump? AN fittings have no sealant at all and are only nipped, otherwise they will Gall and not seal. Those are my suggestions without actual pics. Hope it helps in some way.
Northwest86 is offline   Reply With Quote
Old 02-03-2016, 01:02 PM   #3
GsxrMe
GsxrMe's Avatar
Teflon tape yellow. Never had a problem in the past with my turbo Busa or anything but I'm going to give Permatex Ultra Black a go. If this doesn't fix it I'm half minded to weld the fitting on amd be done with it.
2014 Subaru BRZ
Old 02-03-2016, 09:15 PM   #4
GsxrMe
GsxrMe's Avatar
Thumbs down
I would like to say i'm an ass hat and after doing a tear down I found the -10AN fitting on the turbo side was lose as ____. The oil must of ran down the sleeved line to the oil pan fitting. Not a lot but enough.
I would like to shoot myself in the foot over and over. Someone delete this thread so I never have to think of this again.
2014 Subaru BRZ
Old 02-04-2016, 09:58 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Just to add to this. No Teflon tape or sealant on -AN fittings. Only on pipe fittings.
New car! but this tiny thing is weird bzdont BRZ First-Gen (2012+) — General Topics 17 05-09-2014 12:55 AM
Cool, Tiny USB Stick SocalBurt Electronics | Audio | NAV | Infotainment 62 04-09-2014 09:23 PM
Tiny chip in Windshield JohnATL Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 10-16-2012 03:37 PM
