Old 02-01-2016, 01:41 PM   #1
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
TPMS sensors – Are they worth the hassle?
Hey guys! So as the post title states, are TPMS sensors worth the hassle? Late last year I purchased a 2014 FR-S and this is my first vehicle with such sensors. This spring I plan on getting some tires installed on my Gram Lights 57DR (which currently come with some cool RAYS valves pre installed), and these will most likely be the only wheels that I will be running for the time being. Whether I move the sensors from the factory wheels to the new ones or get new sensors installed altogether, it will cost me extra. So either I pay up or deal with the TPMS warning light.
Could anyone chime in on their possibly, long standing experience with TPMS sensors? I hear they can have a tendency of leaking / malfunctioning and just aren't worth it? Others say they are great. I've tried to research as much as I can on the subject, but any feedback from you guys would be greatly appreciated.
Thanks guys
[YOYO] is offline   Reply With Quote
Old 02-01-2016, 01:45 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks guys
They are only there for emission laws believe it or not. reason being that low tire pressure = bad fuel economy so for all the idiots out there they have added yet another idiot light. If you really want just de-solder the TPMS LED and check your pressures regularly (as you should be doing anyways)
[YOYO] (02-01-2016)
Old 02-01-2016, 01:52 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
as far as I know, the only thing TMPS sensors do, is turn on the light on your dash if presure is too low (26psi I think) or if signal is missing (rims without TPMS or faulty sensor). Why do people give this so much importance is beyond me. There is nothing wrong with not having the sensors on other than the light on the dashboard. If you are the kind of person who never ever checks anything in the car, this might be for you, otherwise, you will see a tire with lower presure the moment before you get into the car. Also, if you had your tires loose presure while traveling, you will feel it with the steering way before the light goes on.
The Following User Says Thank You to Icecreamtruk For This Useful Post:
[YOYO] (02-01-2016)
Old 02-01-2016, 01:55 PM   #4
[YOYO]
Amazing Member
[YOYO]'s Avatar
Yah, here in Ontario Canada, we don't even have those laws, so the sensors are just another annoying piece of nanny hardware that can potentially crap out over time, like so many other electronic bits and bobs on newer cars these days. As for checking tire pressures, that should be an obvious thing. I have an air compressor in my garage and just pump my tires with that.
Old 02-01-2016, 01:58 PM   #5
[YOYO]
Amazing Member
[YOYO]'s Avatar
Right, completely understand. I 'don't think' the light would bother me that much as I've driven around with worse lights only previous builds
Old 02-01-2016, 01:58 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah I am with you on that. Thats why I love AB so much, hahaha noise laws out here are enforced more then running catless.
[YOYO] (02-01-2016)
Old 02-01-2016, 02:30 PM   #7
[YOYO]
Amazing Member
[YOYO]'s Avatar
Exactly. I ran a DC Race header on my RSX for years, and with a KPro ECU and the recent change in Ontario emission laws / new OBD2 based test, it made it a breeze to pass. Mmmmm, fragrant gasoline fumes
The Following User Says Thank You to [YOYO] For This Useful Post:
go_a_way1 (02-01-2016)
Old 02-02-2016, 09:57 AM   #8
avp1
Drives: Traded BRZ for Supra
Yes they do. Good safety feature when you drive car hard. Just imagine tire blow up at 100 mph.
Sent from my GT-I9300 using Tapatalk
avp1 is offline   Reply With Quote
Old 02-02-2016, 10:19 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
How sensors can prevent tires blowing up? :/
Old 02-02-2016, 10:21 AM   #10
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Waste of time... deal with the light and live a happy life
Cockatoo is offline   Reply With Quote
Old 02-02-2016, 11:08 AM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
they come on when your what 2 PSI low? thats not gona make your tire blow up. If you are a responsible car owner you will check your tires regularly. You will also feel a tire start to go low and if you cant you should not be going 100mph
Old 02-02-2016, 11:42 AM   #12
Ashikabi
Ashikabi's Avatar
Cover the light with a flex fuel gauge. Problem solved
Old 02-02-2016, 11:51 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
In many domestic markets world wide millions of cars are sold for decades without any TPMS sensors. Including these toyobarus (not for decades of course ). No sudden statistical spike of blown tires due whatever reasons in those markets ever happened on cars without TPMS, including those that are raced. Checking periodically in some of fueling station visits also tire pressure, or noticing pressure issues visually or when driving works for most 99.99% as good minus annoyances and minus extra costs & TPMS system weight additions involved. Something like buzzer for unbuckled seatbelt has its merits. But TPMS has more cons then pros. One can use it if car is sold with it installed, but imho TPMS by far is not something that should be spent on to install later on.
Old 02-02-2016, 11:54 AM   #14
Ashikabi
Ashikabi's Avatar
I think TPMS only exists so puerile ego don't pay attention to their cars(general populace) don't drive on low or flat tires. A low profile tire is ruined if you drive on it flat, even if only for a block or 2. I don't believe they were designed to prevent blowouts necessarily
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 05:22 AM
TPMS Sensors - What to Buy? Stang70Fastback Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-31-2016 02:01 PM
WTB: TPMS sensors raven1231 Want-To-Buy Requests 0 06-03-2015 05:28 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
