Old 01-31-2016, 01:54 PM   #1
lanemccall_75
lanemccall_75's Avatar
Drives: 2016 Subaru BRZ Hyper Blue
Need opinions and advice on rims please!
Hello I'm new and this is my first post!
Anyways, I have a 2016 Subaru BRZ Hyper Blue and I'm wanting to get off the stock 17" rims and get something bigger.
But I'm curious to see some photo's of 18" vs 19" rims. I am also wondering if there are issues of tire rub or anything like that with the bigger rim sizes?
Thanks in advance, please post photos as well!
lanemccall_75 is offline   Reply With Quote
Old 01-31-2016, 03:01 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Just read sticky thread of tire/wheel directory. Find ones of needed size and follow links to threads with pics.
Old 01-31-2016, 05:47 PM   #3
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
You dont need bigger wheels. You need a lower car and more offset.
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
kch (02-01-2016)
Old 01-31-2016, 06:13 PM   #4
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Bigger wheels will make the car feel slow and heavy. I wouldn't get bigger wheels unless i went turbo and had like 300hp+
Even my subaru has 225/45/17 and it's 300hp. I don't see 18's going well on a 200hp car.
If you want looks and don't care about performance, biggest I'd go is 17x9 with 235/40/17 or 245/40/17
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following User Says Thank You to Mr.Impreza For This Useful Post:
headlikeahole (01-31-2016)
Old 01-31-2016, 06:19 PM   #5
Cmorris8848
Cmorris8848's Avatar
Drives: CWP 2015 BRZ Stock
There are several 18s that are lighter than the stock wheels, so it makes the car lighter and essentially faster
Cmorris8848 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cmorris8848 For This Useful Post:
NyC Zn6 (02-12-2016), ShadowReaper (06-30-2016)
Old 01-31-2016, 07:27 PM   #6
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Two good links for you:
http://www.ft86club.com/forums/showthread.php?t=7535
http://www.frsproject.com/
Do they sell the BRZ in HyperBlue in Germany? I can't find that color on subaru.de.
Or is yours an import or respray?
Old 01-31-2016, 07:40 PM   #7
tyler_win_photo
tyler_win_photo's Avatar
You also have to take into consideration that larger wheels will need larger (and consequently heavier) tires.
tyler_win_photo is offline   Reply With Quote
Old 01-31-2016, 07:45 PM   #8
Cmorris8848
Correct, but if you go with a smaller sidewall, such as my 245/35 then it's still lighter than stock wheels and tires.
Old 02-01-2016, 01:43 AM   #9
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Untrue, for the most part. Looking at JUST the tires, and comparing a stock size (215/45R17) to the size you mentioned (245/35R18) you are still looking at an increase of 2-3 lb for the tire.
Having said that, 2-3 lb isn't the end of the world for a street car. I'm moving to 18x9 wheels and tires, and I'm gaining 4.5 lb per corner. Not an insignificant amount, but I'm OK with the weight gain for street use (I should mention I am gaining 4.5 lb as compared with the wheel/tire combo that came on my Series.Blue. It's actually only 2.5 lb heavier than the typical stock wheel/tire combo.)
This is because if you get a good 18" wheel, you can prevent it from weighing any more than a stock wheel (mine weigh about the same as normal stock wheels.) However, even if the weight is identical, there is still a penalty, because you are concentrating the mass further out, and it's weight towards the outside of the spinning body that contributes the majority of the centrifugal forces that manifest as "heavier" steering.
TO THE OP:
Bigger "rims" won't decrease the gap between the fender and the wheel. At least, they SHOULDN'T unless you are doing it wrong. When you fit a larger wheel, you fit a lower-profile tire. The overall diameter stays the same. As others have mentioned, you need to physically LOWER the car if you want to reduce that gap. Having said that, it should be clear now that taller 18 or 19" wheels won't be any more likely to rub, since the overall diameter stays the same. It's wheel WIDTH that causes problems. A wider wheel and tire combo will start eating away at the clearance you have on the fenders and the clearance between the wheel and the strut/spring tower. The stock tire width is 7". You can do 8" or even 9" on stock suspension with the right offset (just Google wheel offset if you don't know what that means.) Generally, as you increase in size from 17" to 18 or 19", widths increase as well (because a super tall, skinny wheel looks dumb, and is dumb.) So it's not the diameter of the wheel that directly causes problems, but it's the fact that taller diameter wheels tend to be WIDER which is the issue. If you were put a 19x7 wheel on your car, with the proper tire, you'd have just as much clearance as the stock wheel/tire combo.
Stang70Fastback is offline   Reply With Quote
Old 02-12-2016, 04:41 PM   #10
lanemccall_75
No they don't sell them here. I'm an American but the military has me stationed here in Germany so I shipped the car with me!
The Following User Says Thank You to lanemccall_75 For This Useful Post:
Sarlacc (02-12-2016)
Old 02-12-2016, 04:43 PM   #11
lanemccall_75
I'm actually wanting some really big wheels. 18 or 19 inch, fat tires, that's what I want.
Old 02-12-2016, 04:50 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I love my 18's! 18x8 +45 18x9 +42 245/35/18 all around. No rubbing, lowered on Eibach pro kit.
I had the stocks with 225/45. Then went to wider 17's with 245/40 mpss. Got tired of them. IMO 18 is perfect, no need for 19.
stock 17x7 @ 20.6lbs are heavy. Claimed weight on my wheels are 19.8 and 20.0lbs. (didn't get a chance vrify) The stock prius tire is 20lbs. My 245/35/18 weigh 23lbs.
advice, opinions, rims, tires, wheels
Wheels for Silver Ignition? Advice? Size? Opinions? brandon678 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 11-18-2014 05:01 PM
Konig Rims, your opinions? DIF Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-18-2014 01:01 PM
Wheels for Silver Ignition? Advice? Size? Opinions? brandon678 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-20-2014 12:21 PM
opinions on rims whitefrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-08-2012 02:58 AM
DIFFICULT DECISION! Need opinions/advice NWIguy BRZ First-Gen (2012+) — General Topics 23 05-14-2012 11:34 PM
