Old 01-29-2016, 04:42 PM   #1
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
TrackSpec Hood Louvers
One of the major challenges with the FT86, is the ability to extract heat out of the engine bay. While a stock car that is street driven doesn't have any problems staying within normal operating temperatures, cars that are Forced Induction, or are driven hard on the track often have overheating issues.
Another occurrence the more spirited drivers may have noticed, is that the stock hood "flaps" at higher speeds. There is a lot of air trapped under the hood, and to escape, the air wobbles the stock hood, escaping out the side. This produces a few undesirable effects: extra drag, front end lift, and a general feeling of uneasyness about the hood staying in place.
CSG is proud to introduce the TrackSpec Motorsports Hood Louver/Heat Extractor Vents for the FRS/BRZ/GT86.
A major design hurdle was finding a proper model of the FRS/BRZ/GT86 to perform CFD analysis to determine the effectiveness of the hood. Such analysis is often performed, but CSG and TrackSpec discovered that all of the commonly available models had some major flaws: they all assume a flat underbody, and they do not model inside the engine bay at all! With such a flawed model, the analysis would also be heavily flawed, so we set about seeking to make our own model. Unfortunately, with the budget we have, it was impossible to laser scan such a complex shape (the underbody, and more importantly, the engine bay) to get the level of accuracy we sought.
This led us to use the flawed models, with some modifications, to attempt to simulate airflow through the engine bay. This data, being flawed, was taken with a grain of salt, and was used only to try different shapes, angles, and sizes of vents, which would ultimately be verified with real world testing. Due to the complexity of the actual car, real world testing would be the only feasible way to get accurate measurements (we don't have the budget for windtunnel testing... sorry!).
The end result of this testing, is the vent pictured below. The vent is designed to drop into the stock hood, and does several things:
- an overall 43% drop in under-hood pressure at highway speeds
- a 60% drop in under-hood pressure at 120mph!
- A net front downforce (we had to add wing angle during testing to balance the now-grippier front)
- Increased cooling (less pressure under the hood = more air flowing through the radiator; more air being extracted = more air flowing through the radiator)
The above claims were verified with real-world data, and tested at Willow Springs Intentional Raceway, aka "The Fastest in the West" at speeds up to 130mph under race conditions.
MSRP is $329.99, and are now available at http://counterspacegarage.com/produc...-frs-gt86.html
CounterSpace Garage is offline   Reply With Quote
Old 01-29-2016, 05:38 PM   #2
Nab33
Drives: 2018 BRZ tS
Let the battle of the hood louvers begin! Jk, nice design, flows really well with the hood. Any pictures if the underside, and does the oem support need to be moddified to allow for install?
Nab33 is offline   Reply With Quote
Old 01-29-2016, 09:45 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
So we have two new options for vents for our hoods. So how exactly do they compare?
Do you have any underside pics?
What are they made of?
Is there any consideration to rain and other weathering?
How are they finished?
Old 01-29-2016, 10:38 PM   #4
CSG Mike
CSG Mike's Avatar
Pic coming
The vents are Aluminum, and powdercoated satin black.
Covers are being designed, due to popular demand, but at the moment, no. The engine bay would be exposed, the same as any other vented/louvered hood .
Old 02-05-2016, 12:59 AM   #5
CSG Mike
CSG Mike's Avatar
Strange. I could have sworn I posted underside pictures.
Covers are in the works, but some other projects are being finished that are in queue first (Mustang testing, Camaro testing).
Old 02-05-2016, 01:00 AM   #6
CSG Mike
CSG Mike's Avatar
Old 02-06-2016, 10:46 PM   #7
scudzey
scudzey's Avatar
Drives: Subaru BRZ
So I installed mine today and I've got to say is was really easy all things considered. Just gotta make sure you measure twice cut once, and with the templates they provide, it's pretty easy.
I decided to go with a different layout of the install with mine and I'm pretty happy with the way it came out. Clears the Edelbrock SC with ease.
scudzey is offline   Reply With Quote
Old 03-02-2016, 11:38 AM   #8
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
[/QUOTE]
I just want to tag you so you post more pix and bump the post please and thank you.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 03-03-2016, 09:04 PM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Installed a set today on a customers road race Frs. Went very smooth. Thinking about doing a set on my drag car to help keep heat down
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 04-29-2016, 07:44 AM   #10
Kiwis
Kiwis's Avatar
Drives: 2016 Blackout BR86
Any progress on those covers? Interested in purchasing a set except my car doubles as a daily driver that sits outside.
Kiwis is offline   Reply With Quote
Old 05-01-2016, 09:00 PM   #11
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
Would louvers actually be a problem for DD? What's the difference between washing under your hood and having rain and such get in there? I've heard people voice these concerns but don't know why specifically it is a problem
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 05-01-2016, 09:39 PM   #12
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Had the same concerns as you. Just went for it. Few car washes, tons of rain, DD all day errrr day. No problems.
BDotG is offline   Reply With Quote
Old 05-02-2016, 09:45 AM   #13
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I'm waiting for the covers to come out.
Question: Is there any concerns with structural rigidity of the hood with the cutting out significant portion of reinforced parts of the stock hood?
Rookie84 is offline   Reply With Quote
Old 07-25-2016, 07:47 PM   #14
CounterSpace Garage
No. The vents actually provide a substantial amount of rigidity to the hood. The benefit of this louver set is high pressure delta which promotes scavenging of engine bay air (evacuating that hot air). Due to this strong pressure differential, the hood is closed tightly over the engine bay.
TrackSpec Hood Louvers CounterSpace Garage Forced Induction 75 02-21-2017 08:09 PM
LOUVERS? AG3NT_5CARFAC3 Cosmetic Modification (Interior/Exterior/Lighting) 37 01-25-2017 06:55 PM
WTB TRD REAR LOUVERS 86_dion Want-To-Buy Requests 13 05-27-2015 05:12 PM
knockoff louvers? cjsporl1996 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-21-2014 01:09 AM
