Old 01-29-2016, 01:59 PM   #1
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
SRT4 engine swap
Just playing with idea and knowing very well that this would not be an easy swap. This is the neon motor not the caliber motor. I currently have an SRT4 its an ACR edition so I could sell the shell for a pretty penny without the motor. I just rebuilt the motor and trans so I know both are solid. The car puts 291 whp and 317 wtq. These numbers are stock turbo with a full exhaust and my tuner did a really good job. I have plenty of experience with car and motors but not very much with transmissions or conversions. With this being a fwd motor how hard would this be to convert to rwd? I would assume that rotating it the that the trans points to the rear would be the first option. Thoughts? I know that the SRT4 motors can be running 500whp on stock internal and still be pretty reliable. This swap would really just for power and the uniqueness of it and I don't believe the motor is much lighter if any than the FA20.
rosol16 is offline   Reply With Quote
Old 01-29-2016, 02:03 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
http://www.stlsrt.com/forum/viewtopic.php?f=20&t=10176
This is the only RWD SRT swap I have seen. I had a CSRT4 for a while as my daily and it was a blast. I don't think this would be a good swap for various reasons, but I did always want to build a kit car cobra with an SRT4 motor just to see the looks and to upset people when they saw the motor.
Old 01-29-2016, 02:17 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just dump it in the trunk and make it a mid rear engine car LMAO!!
Old 01-29-2016, 02:22 PM   #4
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
your biggest concern would be making a bell housing adapter for whatever transmission you chose to go with. Once you tackle that all the wiring, motor mounts and various other little things you'll need to modify to make it fit should seem like cake.
Gear_One_Performance is offline   Reply With Quote
Old 01-29-2016, 02:22 PM   #5
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
+1 for not 2J, LS, RB.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 01-29-2016, 02:30 PM   #6
rosol16
Not A Member
rosol16's Avatar
yes
That was actually a thought as well I mean that would be badass just to have lol and then we could get real crazy and go AWD!!
I would probably try to use the T850 Quaffe that's in it if possible no sure if it is. Its a durable transmission for being stock many people run 500hp on this stock as well its the axles that I'm worried about. But if there is a will there's a way
Always gotta be unique a lot of people hate on the SRT4 but must will still agree that's its a great motor.
Old 01-29-2016, 02:43 PM   #7
Anthony
Weight Nazi
Anthony's Avatar
I like the FA20 and would never swap to another 4 cylinder.
But... if you've got a stock FA20 in your car, but a fully built 4 banger sitting around, I can see it being worth it. My main concern with engine swaps is always balance and center of gravity. It's hard to beat the FA20.
Old 01-29-2016, 02:45 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
And this is why I will never do a swap. I didn't buy a light nimble sports car built really for nothing but corners just to make the front end 300 pounds heavier and ruin its balance
Old 01-29-2016, 02:56 PM   #9
rosol16
Not A Member
rosol16's Avatar
I think the weight is the same and I wouldn't consider fully built but pretty close. Its JE forged pistons, Eagle rods, Titanium springs and retainers, Brian Crower S3 cams, ported polished head, Bored .20 over, machined crank, and strapped oil pan, and trans has a few upgrades as well. I don't think this would up set the balance that much weight wise maybe even lighter but it would change the center of gravity for sure
Old 01-29-2016, 03:01 PM   #10
Anthony
Weight Nazi
Anthony's Avatar
Yeah, close enough for sure.
Old 01-29-2016, 03:37 PM   #11
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
where are you at that the srt-4 shell sells for a pretty penny?
The swap would not be worth it at all. Unique, sure. But not worth the massive hassel. Hell, a regular swap is still TONS of work, and thats with people who have already paved the road with some info/guides.
I used to own an srt, btw.
Old 01-29-2016, 04:01 PM   #12
NOHOME
Drives: RAVEN
That recipe does not do a thing for me.
But it's your car, your time and your money, so please do keep us posted on how it goes. I am impressed by anyone who has the skills to do a clean swap regardless of the mix.
NOHOME is offline   Reply With Quote
Old 01-29-2016, 05:07 PM   #13
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Vorshlag Motorsports, who are doing an LSx swap in their FR-S, looked at the arrangment of the FA20 in the chassis and ascertained that, while low in CoG, it is heavy and not great for F:R weight distribution. The bell housing of the transmission is long, necessitating a long shift linkage, and more than 1/2 of the engine mass is in front of the front axle centerline. The FA20 is also the heaviest four cylinder aluminum engine they've ever weighed (presumably of similar displacement).
Skip to the "What's So Wrong With The Subaru FA20 Boxer Engine?": http://www.vorshlag.com/forums/showthread.php?t=8275
I personally wouldn't ever swap a V8 into this car, I think the FA20 is perfectly suited for this application. Especially since I don't ever really plan to mod the engine for power. For reliability? Yes. I think if anything, it seemed like maybe the engineers could have improved the weight distribution by moving the engine rearward and used a shorter bell housing, but perhaps the bean counters intervened. I could see an argument for change in that area, but not swapping the engine entirely.
BUT. Some people want MOAR POWER. And that's totally legit.
It's probably impossible to get a similarly low CoG with another engine (except maybe with another horizontally opposed powerplant). But if you're willing to look past that, I don't see why an SRT mill or similar wouldn't be eye-wateringly fun in this chassis.
I'm personally waiting for someone to swap in a frankenstein Honda K24 into a Twin. K24 block, K20 head, TVS1320 positive displacement blower with A/W chargecooling, figure out a way to keep the gears from eating themselves and I'm sure you'd have a reliable track-ready weapon on your hands. Even though the CoG would be higher, you'd likely lose some weight in the process and gain a BUNCH of power and torque. Hell, even if you decided on an all-motor build, you'd get much more torque with the extra displacement not to mention a much more reliable motor with better fuel economy without all the direct injection complication. Of course, you'd probably have a nightmare of a wiring job awaiting you to integrate the gauges and various sub-systems.
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 02-01-2016, 09:20 AM   #14
rosol16
Not A Member
rosol16's Avatar
It only cause its the ACR edition. Its black paint code PX8 so there were only 433 made and somewhere around only 250 left. I have people that just wanna buy my shell for almost 4k but I have refused to part it out as it makes me smile everytime I drive it. I don't understand why someone would pay 4k for just the shell when you can get a whole decent SRT4 for 4k but hey whatever they wanna do.
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
caliber srt4 Silverdub FR-S / BRZ vs.... 26 07-19-2013 02:25 PM
4-AGE engine swap on FR-S bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 31 12-16-2012 02:23 PM
4-aGE engine swap on FR-S bacon_cheese_beer Engine Swaps 13 12-15-2012 03:29 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
