Old 08-23-2014, 10:38 AM   #1
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Sub frame risers
So from what i read, the axles get a lot of stress when our cars are lowered. A couple different people already shared their broken axle stories. Has anybody bought sub frame risers? Is it worth the $100? Anybody make their own?
-Dave
DavidBob is offline   Reply With Quote
Old 08-23-2014, 10:48 AM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
It's definitely worth the $100 for the reason of it making a huge difference in axle angle. The big downside is the VERY LOUD NVH that's added to the ride. The diff whine is very loud and it would probably suck for anybody using the car as a daily driver-unless you really just don't give a f*ck.
What are you using the car for? If it isn't slammed or you're not making more power or running a lot of grip, it might not be a big issue.
I use mine for drifting and on my first event, I had a slight issue with the axles. Got it fixed and dialed out some rear grip by increasing tire pressure and have yet to have an issue since. All on stock power level
TylerLieberman is offline   Reply With Quote
Old 08-23-2014, 09:02 PM   #3
DavidBob
DavidBob's Avatar
Yeaa its my daily driver and occasionally I drift it, I'm lowered but I'm not slammed nor will I be making any more power. No moneys for more power yet
What kind of issues did you run into if you don't mind me asking.
Parts Shop Max subframe and differential risers philstar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 02-20-2024 11:05 AM
Door frame paint shaofis Issues | Warranty | Recalls / TSB 15 06-08-2015 12:29 PM
Parts Shop Max Subrame and Diff Bushings/Risers AxisPower Brakes, Suspension, Chassis 2 09-27-2014 03:39 PM
Does this look like frame damage? frsinpa Issues | Warranty | Recalls / TSB 15 04-24-2014 11:29 AM
Frame or no frame? Missy Scion FR-S / Toyota 86 GT86 General Forum 33 12-03-2013 11:47 PM
