Old 01-28-2016, 01:34 PM   #1
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
anti-lag?
Gents
what with the amount of large turbos on this forum
I was wondering has anyone experimented with using a really late GDi timing and spark retard to give in essence anti-lag and so spool the turbo up.
its something more and more OEM's are using as rather bizarrely if you don't give it a lot of fuel you end up very very lean about lambda 1.3 and this doesn't contain enough fuel to burn hot so its not like the anti-lag of old where things all melt
the BMW engines all do this which is why they can get 250+ ft/lb at 1500rpm on their turbos
your thoughts?
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (09-07-2017), lamawithonel (01-30-2016)
Old 01-28-2016, 02:22 PM   #2
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
One of the more well known tuners James Martin has done something like this on stock ecu. Unfortunately, he is banned here
[ame="https://www.youtube.com/watch?v=JPskKzBy6mY"]FRS antilag - YouTube[/ame]
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
The Following 6 Users Say Thank You to #maverick# For This Useful Post:
ajc209 (02-01-2016), Bykov (04-01-2016), DustinS (01-28-2016), Freeman (01-28-2016), Ramn (01-28-2016), whataboutbob (04-01-2016)
Old 01-28-2016, 03:37 PM   #3
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i was making about 10psi off the line on a precision 5858 with ecutek launch control
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 01-28-2016, 04:22 PM   #4
Matt@Cosworth
Yes with launch control though you hold a high rpm so 4000rpm?
I'm more interested in a normal driving situation where you just roll on the throttle at low rpm
Ramn (01-28-2016), wparsons (01-28-2016)
Old 01-28-2016, 09:44 PM   #5
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by Matt@Cosworth View Post
Gents
your thoughts?
The high compression ratio of the FA20 helps spool up the bigger turbos so there isn't a great need to play with this stuff. You cruise at about 2.5k so boost at lower RPMs isn't needed.
That being said, I'm going to implement a rally style ALS later this year. Just for the sound :-D
86drift is offline   Reply With Quote
Old 01-29-2016, 09:26 PM   #6
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Why is James Martin banned?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
IBill4You (08-03-2016)
Old 01-29-2016, 10:27 PM   #7
funwheeldrive
Is this similar to a stutter box?
Old 01-30-2016, 03:03 AM   #8
Matt@Cosworth
its more to get a big engine feel really, you're right in saying that you don't 'need' the boost at 2.5K but its like having a 3.5ltr v6 instead of a 2.0ltr 4 you can be tickling along at 1500rpm and just roll on the throttle and it pulls hard
so no-one apart this fellow who's banned?
Old 01-30-2016, 11:08 AM   #9
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Gents
your thoughts?
I'm interested. You have my attention.
If you have anything you'd like to try, I have a tuning device and an engine I'm willing to blow up.... I mean, experiment with.
Coincidentally, this motor has sodium-filled exhaust valves from the factory, so they're very temperature tolerant... The GDI seals are not.
I worry a little about detonation at Lambda 1.3 and any boost though... The late timing should help, but then I'm not following where all the torque is supposed to be coming from if you back the timing off that much... If you transition back to traditional timing/fueling at low RPM, I'm liking the chances of transient detonation during the transit, and you'll likely lose any turbo spool you had...
I'm not arguing, I'm musing. I'm curious, but I'm afraid it's beyond my tuning knowledge.
I see in the Martin youtube video he passes 5 PSI pretty early, but not 1500 early, more like 25-27..
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 3 Users Say Thank You to Spartarus For This Useful Post:
DustinS (01-30-2016), lamawithonel (01-30-2016), Teseo (02-01-2016)
Old 01-30-2016, 03:14 PM   #10
OkieSnuffBox
Drives: '23 BRZ Limited
Video earlier is not anti-lag. That looks like launch control.
The reason street cars don't use anti-lag is because it destroys everything. Rally cars use it for increased transient response from on/off throttle applications.
Making it crack/pop on decel is one thing (not anti-lag), true anti-lag kills everything quickly.
Old 01-30-2016, 03:30 PM   #11
Matt@Cosworth
the 1st thing to try is just going for a really late Gdi timing?
So try about 150 degrees later than normal this will produce odd lambda readings due to the post combustion but you should also see a positive increase in boost
86drift (02-07-2016), ajc209 (02-01-2016)
Old 02-01-2016, 05:23 PM   #12
#maverick#
#maverick#'s Avatar
Something about the Admins being Nazis or something like that
The Following User Says Thank You to #maverick# For This Useful Post:
Dream20b (02-02-2016)
Old 02-04-2016, 03:54 PM   #13
BBDGriptonia
Drives: blah
I am in for results
Who's testing this concept?
BBDGriptonia is offline   Reply With Quote
Old 04-01-2016, 12:08 PM   #14
FRS Justin
Drives: 2013 Asphalt FRS
Any further development???
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
coolant/anti freeze Newtothegrounds Engine, Exhaust, Transmission 44 07-04-2017 06:39 PM
FS: Eibach Anti Roll Kit (From Pro-Plus Kit) Batman Brakes, Suspension, Chassis 1 03-31-2014 03:02 PM
FS: NY RCE Sway/Anti-roll bar kit $250 snky_snky Engine, Exhaust, Bolt-Ons 2 08-18-2013 12:09 PM
Anti Theft Function Cyau Scion FR-S / Toyota 86 GT86 General Forum 22 06-25-2013 05:58 PM
BRZ Anti Theft system Skurj BRZ First-Gen (2012+) — General Topics 15 01-21-2013 03:38 PM
