Old 01-27-2016, 06:09 PM   #1
pleasurevictim
Drives: ZN6
Throttle body spacer
Have a Torque Solutions throttle body spacer for sale. Brand new only opened to check contents. Can ship at buyers expense. $70 brand new asking $55 obo.
pleasurevictim is offline   Reply With Quote
Old 01-31-2016, 06:56 PM   #2
pleasurevictim
Drives: ZN6
Bump
Old 02-01-2016, 12:45 PM   #3
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
is there any dyno sheet on this ?
irax is offline   Reply With Quote
Old 02-01-2016, 12:47 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
gains (if any) on any Throttle body spacer usually fall within the tolerance on any dyno therefore a dyno run is not a good way to measure if these work.
Old 02-01-2016, 04:44 PM   #5
Gringosteve
Drives: UK Spec GT86
What benefits do they provide
Gringosteve is offline   Reply With Quote
Old 02-01-2016, 04:48 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
They are supposed to either help smooth air flow and they also effectively change the intake length, however they are used in front of the TB so I am not sure if the theory holds true when used in front of the TB. I am no expert though.
edit: some can even work as a "velocity stack" depending on the shape
Old 06-19-2016, 02:13 PM   #7
pleasurevictim
Drives: ZN6
bump
Old 11-09-2016, 07:54 PM   #8
pleasurevictim
Drives: ZN6
bump
Throttle body spacer wootwoot Engine, Exhaust, Transmission 15 10-14-2014 06:14 PM
