Old 09-04-2014, 03:15 AM   #1
wootwoot
Drives: FRS
Throttle body spacer
This popped up on ft86 speed factory:
http://www.ft86speedfactory.com/torq...d5257b72d4e8ca
Anyone have any experience with these sorts of things?
wootwoot is offline   Reply With Quote
Old 09-04-2014, 04:00 AM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
From the amount of research I've done on TB spacers, if the injector is located where the spacer would be than it would have some actual gains. Since the TB and the spacer would be farther away, it's more or less just adding an insignificant amount of cfm into the intake mani. A better solution would be the BPB since they're like spacers for the actual intake runners near the injectors.
My .02 cents. If anyone has hard data backing up their claims of a TB spacer working on this car, please post it
Old 09-04-2014, 05:29 AM   #3
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Don't see any big gains coming from it, but one in red would add a good touch to the engine bay. Plus I'd get it if I can get a bigger body throttle or somehow have our OEM one modified
Carlitoz3 is offline   Reply With Quote
Old 09-04-2014, 08:18 AM   #4
Davev
TuRD
Davev's Avatar
Drives: FR-S Mono Mt Fuji Red
It's aluminum so you could anodize it any color. And a port for nitrous, too! I thought I saw thread about a guy that can open up the TB?
Davev is offline   Reply With Quote
Old 09-04-2014, 08:57 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
There are larger TB on the market but they are expensive. Cusco and Toda do them.
My understanding of the TB spacer is to increase plennum volume which can improve torque and power if the stock plennum is undersized.
1974 TA22 Celica
2013 86 GT
Old 09-04-2014, 09:30 PM   #6
Poodles
Drives: 2015 Series.Blue
One would be a bit foolish to think that the OEM wouldn't have tested this exact thing in the design of the manifold...
TB spacers have been a scam since day 1.
Old 09-04-2014, 11:16 PM   #7
zooki
Drives: waiting on a 2021...
Throttle body spacers usually work on TBI systems, where the injectors are in the throttle body itself. They are used sometimes to give the air/fuel mixture a little more room to homogenize before being sucked(or actually pushed) into the cylinders. They can also help increase the plenum size a bit to help in the upper RPM's, but they have to be pretty large.(think a 2" carb spacer on a race motor) On a port or direct injected motor I can't really see a benefit, as the small increase in plenum size the spacer would add really wouldn't be noticeable on the top end.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 10-10-2014, 01:41 PM   #8
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Just ordered one. Might use it with my TODA tb(using stock TB atm), see how that goes.
stevo_12v is offline   Reply With Quote
Old 10-12-2014, 04:12 PM   #9
xcelir8brz
Drives: 2013 BRZ Limited
I have the CBPB and thinking about this spacer as well in parallel.
I did a similar setup on my '04 TL (both spacers) and noticed significant gains in tandem.
Your thoughts?
xcelir8brz is offline   Reply With Quote
Old 10-13-2014, 11:03 AM   #10
wparsons
wparsons's Avatar
Look for independent dyno results for a TB spacer (or bigger TB while we're at it). You won't find any that actually show any gains.
flickr
Old 10-13-2014, 11:19 AM   #11
s2d4
s2d4's Avatar
I beg to differ, their wallet will be lighter and their butt dyno will justify it.
Old 10-13-2014, 05:02 PM   #12
SpeedR
First86 / boat thief
Drives: MKIV Supra
TB spacers only work with octane boosters.
Also dont forget to check your blinker fluid regularly.
SpeedR is offline   Reply With Quote
Old 10-13-2014, 10:58 PM   #13
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
@jamesm did back to back dyno pulls on a stock car with and without the spacer and found it to have no performance gain.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 10-14-2014, 07:12 AM   #14
xcelir8brz
Hmmm. Thanks for input.
FA20Club Throttle Body JDogg Engine, Exhaust, Transmission 22 12-01-2014 04:00 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
