UCSB!!!
Drives: 2017 GTI sport
Supercharger Throttle Lag?
Sorry if this question has been asked before but I couldn't find it anywhere.
Anyways, whenever people are comparing superchargers to turbochargers people who prefer superchargers do so because of linear power delivery and throttle response. The question is, shouldn't superchargers also hamper throttle response? After all, it is belt driven and the added mass needed to spin the supercharger would practically negate the benefits of a lightened flywheel or light weight crank pulley. |
#2 | |
Fast enough
Drives: 2013 Subaru BRZ AT
In fact the throttle is almost a little too sensitive now. I have to get used to driving it. I've had Moto-Mike scale back the throttle sensitivity some to help. |
Drives: 2013 FRS
I am curious about this too. It sure would be interesting to compare the ECU logs from two similarly powered Turbo/Supercharged 86's.. a run from 2k RPMs to redline at WOT. You could plot, time, engine RPM, vehicle speed, MAP, etc and actually come up with a measureable and comparable "throttle response" view.
#4 | |
Senior Misanthrope
Sarcastic SOB
I have a lightened pulley which might partially compensate.
In the case of the HKS centrifugal unit, it is virtually identical to the Rotrex unit EXCEPT that one of the 3 internal rollers, (which act as gears except they can slip under low load,) is spring loaded and really slips at lower RPMs so in fact there is minimal added load until the revs are up a bit, maybe in the 3000 RPM range. This is to reduce parasitic power loss and improve fuel economy, but I believe it also minimizes throttle response latency.
| The Following User Says Thank You to wbradley For This Useful Post: | HachiEnam (01-27-2016) |
#6 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | HachiEnam (01-28-2016) |
#7 | |
Throttle response is the delay, or lack thereof, from when you step on the gas to when the engine responds with output. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | sw20kosh (01-27-2016) |
UCSB!!!
What about the rate the rev climbs or falls? Is there any difference?
| The Following User Says Thank You to HachiEnam For This Useful Post: | jvincent (01-27-2016) |
Drives: Toyota 86 Turbo, Lexus NX300H
http://www.datazap.me/u/yobiwan/sc9?...0&zoom=520-737
http://www.datazap.me/u/yobiwan/42mm...zoom=1124-1298 I'm using HKS v2 s/c . and almost no lag for me too. About the rate, I don't feel any difference when climbs, but I think it's faster when falls. |
#10 |
Drives: 2013 Black FR-S
None.
#11 | |
Drives: 2013 FRS
If you had them all plotted over time you could see how long it would take to make a certain amount of power after the throttle went to WOT. Ok, so you don't have to go to redline... unless one was REALLY laggy! heh. On a dyno you don't get to see throttle plotted with the power, so not able to get it there, but I'm sure you can figure out roughly the power level from other ECU prameters. Now that I think of it, the dyno shop I use just got WinPep 8 setup which has an OBD connector and can log all the OBD stuff. Maybe when I get the Edelbrock setup dyno'd I'll see if I can have it added... |
#12 |
Drives: White 2014 BRZ
Well lets be honest under about 4k centrifugals don't make much boost. Above 5k is where they take off. Granted in first or second gear it will probably feel instant.
JDL Turbo kit - Ecutek, HRI tuned.
#14 |
That depends purely on setup. The same could be said about turbos; the boost threshold is determined by setup.
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
| Full Throttle 1.5 Supercharger for sale | jpit | Engine, Exhaust, Bolt-Ons | 3 | 12-12-2015 11:40 PM |
| Supercharger hose/throttle body clamps -- how tight? | speedy | Forced Induction | 6 | 06-26-2014 09:59 PM |
