Drives: Frs 2014 MT whiteout
Brake lock up after car wash
After washing my frs and putting in the garage, I have found that the next day I get in it to drive, the car will not move in reverse ( or forward) without me revving it up to overcome the locked up pads on the rotors. Anyone else had this issue and how did you fix it? I have researched this issue on other car forum and found some answers, but just want to hear anything specific to our cars.
Never happen to me on other cars..
Drives: 2014 BRZ SCCA STU endurance car
That's fairly normal, it's usually from a very light coating of rust between the rotors and pads. It gets wiped right off the next time you hit the brakes.
Drives: 2013 Pearl White 6MT
Always brake test it after washing to keep this from happening.
@RichardsFRS you mean have a drive around the corner after wash, to make the brake works a bit? The problem it is winter right now and there is dirty slush out there, don't want to get it dirty right away.
#5 | |
The drum/shoe emergency brake may not be releasing till you drive a few feet. If you are setting the brake, I suggest you not set it and just leave your car in gear (assuming your garage floor is relatively level). If you're not setting the brake, and the pads are sticking to the rotors, I wouldn't worry about it. humfrz |
#6 | |
BRZZZZZ
Drives: 2013 BRZ Whiteout
Did it make a little clunk sound as soon as you started to move.
Whenever I use my e-brake and park my car for a day or two, it somehow locks itself even if I release the e-brake lever. As soon as I start to roll, the e-brake disengages and makes a light clunking sound. It happens on my other car also, specially if I park in my driveway which has a slope. |
@humfrz
yes I have e-brake up, yea I will try just in gear after wash next time. Never happened in summer, maybe brake surface oxidation much quicker in winter with all the salt we have here...
#10 |
I Love custom Turbo kits
Drives: Limited BRZ
Brake rust, completely normal. Don't even worry about it.
#11 |
Yea you can drive around the corner or just jump forward and slam the brakes. They'll sound awful but it shaves the rust off
#12 |
Drives: old
Seeing as you live in the great white north, you sure the water left on the pads or shoes isn't just freezing?
| Is it possible to get hydro lock through car wash? | Muskokan | Issues | Warranty | Recalls / TSB | 1 | 10-15-2014 02:37 PM |
| CG Lock Seat Belt Lock | Biggins | Interior Parts (Incl. Lighting) | 0 | 02-03-2014 08:41 AM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Can you recommend a hand wash car wash in Las Vegas | whaap | Southwest | 3 | 05-14-2013 06:55 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
