Old 01-23-2016, 11:25 PM   #1
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Funny smell from dead headlight (BRZ Bi-Xenon)
So I noticed my Driver's side headlight bulb went out tonight. I thought that was odd since it's less than a year old replacement bulb from @Diode Dynamics. The stock bulb had lasted up to that point, which puts it at about two years.
When I pulled the cap and connector, I smelt some really foul smell, and looked at the connector and it looked a little dirty inside (compared to other side to confirm, no smell over there either). When I pulled the bulb out, it didn't have that smell, so it seems to be from the connector. I put the factory bulbs back in for now and they are both working at least right away, no extended use yet.
Any info? Is it a normal smell when these types of bulbs die? But why would it die after only about 10 months?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 01-24-2016, 12:14 AM   #2
ryoma
ryoma's Avatar
was your replacement bulb an OEM bulb, or a Diode Dynamics aftermarket bulb? how do the wires look on the connector?
Old 01-24-2016, 10:17 AM   #3
Freude am Fahren
It was whatever DD sells as "OEM Replacement" They're not the same as stock, which are labeled as Osram, they have no writing on them. Wires look fine.
Old 01-24-2016, 02:40 PM   #4
ryoma
ryoma's Avatar
it might be just a bad bulb then. your best bet will be to use an OEM part, which are the Osram bulbs.
The funny smell everyone talks about.... ricky rod Scion FR-S / Toyota 86 GT86 General Forum 6 06-13-2015 09:25 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
HID Single Xenon or Bi-Xenon? FriedRicr DIY (Do-It-Yourself) Guides 1 04-06-2013 10:06 PM
Xenon kits for FR-S (35w vs 55w) mit_peid Cosmetic Modification (Interior/Exterior/Lighting) 9 02-28-2013 01:09 AM
Xenon and/or LED DRL? Z_Rocks Scion FR-S / Toyota 86 GT86 General Forum 30 12-11-2011 11:56 PM
