Old 01-23-2016, 09:56 AM   #1
Fred Flintstone
Drives: 2015 FR-S Asphalt, racing stripes,
Brake pads
Best pads for improved stopping for a street vehicle. Should I go with ceamic even though I plane to keep rotars and calipers for now.
Fred Flintstone is offline   Reply With Quote
Old 01-23-2016, 10:14 AM   #2
Tor
Tor's Avatar
Drives: Toyota GT86
No, you should go with Sintered.
http://www.essexparts.com/storage/wy...e%20pads_3.pdf
Tor is offline   Reply With Quote
Old 01-23-2016, 10:43 AM   #3
shellslinger
Drives: Whiteout FRS
I have winmax w2 brake pads. Awesome brakes, a little more bite than oem but stops really hard and linear. But there's a lot of brake dust compared to oem.
shellslinger is offline   Reply With Quote
Old 01-26-2016, 11:26 AM   #4
CatDaddysBBQ
Drives: '13 FR-S
I have the stop tech pads on both axles. I also have upgraded to SS lines, but that shouldn't make too much of a difference. The stoptech's are more than anything I could want in a street pad. They are JUST OK ON TRACK but get hot after 15-20m. I wouldn't recommend them for track use as a result.
But for a street car that sees autoX even? They're cheap, strong and wear well. Work in winter, summer and everything in between, and the car stops SO much better than stock.
CatDaddysBBQ is offline   Reply With Quote
Old 01-26-2016, 11:40 AM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We definitely can help you out based on your needs and application.
CounterSpace Garage is offline   Reply With Quote
Old 01-26-2016, 12:22 PM   #6
strat61caster
strat61caster's Avatar
I can only think of 3 reasons not to use the OE calipers and rotors:
1. You are spending a small fortune on brake pads (click here for link)
2. You are competing and the weight reduction and potential change in bias is beneficial to warrant the expense (likely hand in hand with #1)
3. Hardparking
OE brakes just need a fluid flush and appropriate pad choice and they will hold up to pretty much everything a casual/amateur could want. Since you're not leaving public roads you probably don't even need a fluid flush until it's time for maintenance.
ineedyourdiddly
Old 01-26-2016, 05:19 PM   #7
sprintamx
I don't mean to preach, and I don't know you're particular experience, but there are lots of factors to consider, and there's already been VERY GOOD advice about staying "street" for the street, i.e., OE. But, swapping out pads is a relatively easy--if not inexpensive--way to fiddle, experiment, and possibly find improved braking; which is always a good thing, I think.
So, take a look at the lower number Winmax compounds, or Ferodo DS2500--my personal favorite. Just remember that you need to use performance pads as intended to avoid glazing them.
sprintamx is offline   Reply With Quote
Old 01-26-2016, 10:07 PM   #8
stevesnj
stevesnj's Avatar
I have the W2's, awesome!!! Haven't tried them on the track yet but I think these should be just right. You should also flush out the stock brake fluid for a higher performing fluid.
My 2016 Build thread
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
