Old 01-22-2016, 01:55 PM   #1
StrayJay
Drives: 2016 Scion FRS
Stage 2 tune without Supercharger or Turbo
So not knowing a lot about tuning, can I put a stage two tune on my car without a supercharger or a turbo? I'm adding a few more modifications before I add it, most likely a few more exhaust/pipe modifications.
StrayJay is offline   Reply With Quote
Old 01-22-2016, 01:57 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Stage one is for a car with OEM header or cats
Stage two is for a catless car
thats basically it
Old 01-22-2016, 01:59 PM   #3
Jonathanlim
Drives: 15' Frs
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune
91 (USA) octane or better required for 91 octane tunes
93 (USA) octane or better required for 93 octane tunes
http://www.ft86club.com/forums/showthread.php?t=71157
Jonathanlim is offline   Reply With Quote
Old 01-22-2016, 01:59 PM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
Stage 2 usually refers to a tune for catless header. If you add Forced Induction, you'll need a different tune for that.
Old 01-22-2016, 02:03 PM   #5
StrayJay
So a Stage 2 adds more horsepower than Stage 1 correct? Anybody know how much more exactly?
Old 01-22-2016, 02:10 PM   #6
Jonathanlim
Drives: 15' Frs
Refer to this it has all the info. http://www.ft86club.com/forums/showthread.php?t=81493
Old 01-22-2016, 02:12 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yes but mainly due to the fact you have no cats restricting flow
Old 01-22-2016, 02:22 PM   #8
D_Thissen
D_Thissen's Avatar
Search is your friend
Old 01-22-2016, 02:49 PM   #9
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
When you say stage 2 we need to know what stage 2 you are referring to. Plenty of supercharger or turbo kits have a stage 1 or stage 2 and Open flash tablet also has its own stage 1 and 2.
I'm going to assume you are talking about Open flash tablet and someone already posted a link to it above that is way more in depth.
Quick Rundown
Stock car works with:
Stage 1 with 91 or 93 depending on what is available in your area
Stage 2 E85, should be self explanatory but this tune is only to be used ethanol based fuels. This will net you a solid hp and tq increase but you will lose fuel economy.
This applies to most naturally aspirated cars as long as they have not replaced their factory headers with some type of high flow or catless header.
Catless Header
Stage 2 91 or 93 but you also need to make sure you pick the correct header configuration between UEL and EL.
DO NOT JUST PUT STAGE 2 ON YOUR CAR BECAUSE MOAR POWAAAHH BRUH!!!!!!!!! The stage 2 tune does not just magically give you more power for free especially if you do not have the components it is designed to work with. It has been designed to work with less restrictive exhaust components to maximize the power you already have.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 01-23-2016, 10:42 PM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm assuming your speaking of openflash stage tunes, I'm not entirely sure they'd work in an FI application you'd definitely need to get a custom e-tune.
This is what's written in the README that comes with the Off-The-shelf tunes when you download them:
Vishnu FA20 OTS Map Release Notes
OTS Map Requirements:
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only.
Different for each car and conditions, but you can assume so, because the stage 2 has more aggressive modifications
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 03:38 AM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
AVO Stage 1 Turbo Kit -- BONUS: FREE AVO BOV, UPGRADED TUNE & OVER-NIGHT SHIPPING Jason@DSG Forced Induction 52 05-07-2014 07:04 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 08:29 PM
