Old 01-22-2016, 01:31 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Timing cover slow leak, aftermarket solution and supercharger effect to this area?
It was fixed under warranty the first time but noticed it's leaking again. I'm hoping they'll fix it again and it'll be good but in case it leaks a third time. Are there any aftermarket solutions to this? I don't want to rebuild the engine but do they make an aftermarket cover replacement?
The leak is so slow that I don't even pick it up from the oil dip stick but I would like to keep the car for a long time with plans to supercharge it. If supercharging, I've read that this area is not a pressurjzed area and would just be subjected to increased heat. Would a supercharger greatly exacerbate the leak?
tracerit is offline   Reply With Quote
Old 01-22-2016, 08:58 AM   #2
Ashikabi
Ashikabi's Avatar
Use RTV gasket when putting it back together(dunno name brand). Otherwise, let it leak? Supercharger shouldn't affect it
The Following User Says Thank You to Ashikabi For This Useful Post:
humfrz (01-22-2016)
Old 01-22-2016, 10:46 AM   #3
tracerit
I'd like to get this fixed under warranty again, so hopefully whatever they're using is of the same quality as what you've mentioned.
Supercharging would increase the Temps I'd imagine, so I would plan for an oil cooler and look into higher quality coolant as well. As long as the leak isn't worsened by supercharging, I'd be okay going underneath to clean it up every two months or so.
Old 01-22-2016, 11:02 AM   #4
Ashikabi
Ashikabi's Avatar
Just ask them to use RTV or formagasket or whatever when they fix it. They probably just use the factory rubber ring. If they did use RTV already, they probably didn't clean it properly before application
tracerit (01-22-2016)
Old 01-22-2016, 04:05 PM   #5
humfrz
hmmmm.........folks, yes, the "cam plate" has an "O" ring ....... but I don't believe the "timing cover" has any gasket (it's sealed with sealant only).
So, the fix depends upon which one is leaking........
humfrz
whataboutbob (01-22-2016)
Old 01-22-2016, 04:06 PM   #6
Ashikabi
Ashikabi's Avatar
humfrz
Then perhaps they just didn't clean it right when they "fixed" it
Old 01-22-2016, 04:21 PM   #7
humfrz
Good point.
My theory is that when some mechanics "pry" off the timing chain cover, they bugger up the soft aluminum cover and/or block, by using tools (like the crowbar in the picture).
So, after they put it back together, it still leaks.
humfrz
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
