Old 01-21-2016, 08:49 PM   #1
Docmattic
Drives: GT 86
Best bang for buck oil cooler
Hey Guys,
I've recently installed a sprintex 210 intercooled supercharger system. I'm looking for an oil cooler. I've been thinking about the mishimoto option. Is here any feedback or suggestions for others.
I"m looking for one that offers good performance for the money, but is not necessarily top of the line. I think its a good idea i get one as i will be doing spirited drives, but i will not track the car.
Edit: I forgot to mention i do live in a coldish climate (-6C in Winter) so I need to to heat up quickly in winter as well.
Cheers,
Nick.
Docmattic is offline   Reply With Quote
Old 01-21-2016, 09:42 PM   #2
1Cor10:23
1Cor10:23's Avatar
@Docmattic check out the racerx kit. I strongly believe their thermostatic sandwich plate to be the best design on the market.
Old 01-21-2016, 10:25 PM   #3
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm happy with my @Maximal kit
Old 01-22-2016, 10:57 AM   #4
Mishimoto
Drives: 2013 Subaru BRZ
Originally Posted by Docmattic View Post
Hey Guys,
Cheers,
Nick.
Thanks for considering our oil cooler kit Nick. In a climate such as that, you are definitely going to want some form of thermostat in the system. We do offer a kit with a thermostatic sandwich plate, which includes a 85°C thermostat. This unit is serviceable and can be swapped for a 71°C or 93°C unit.
In terms of performance, we use a very efficient 19-row cooler which is mounted within the front bumper. The cooler sees a ton of airflow which translates to impressive heat transfer. On a similar sized engine with similar airflow, we typically see temperature drops of around 15°C -20
°C from inlet to outlet.
Let me know if I can answer any specific questions about our kit. If you do end up deciding to purchase, be sure to check with our vendors for the best available price.
Thanks
-John
Mishimoto is offline   Reply With Quote
Old 01-22-2016, 11:13 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Hey Guys,
Cheers,
Nick.
Hey I run a @Mishimoto cooler and it works great for me. I do take the thermostat out all together for the winter to minimize oil flow to the core, however I do see -35C in the winter. My oil temps sit at 190F (with no thermostat in the winter) same as water temps and doesn't take much longer to warm up at all.
Old 01-22-2016, 09:20 PM   #6
sam69
Drives: GT 86
I have been running this kit for well over a year with no issues . http://www.ebay.com.au/itm/Thermosta...UAAOxyJX1S-zZt
Only thing I did was open and smooth the ports in the thermostat sandwich plate for better flow .
sam69 is offline   Reply With Quote
Old 01-24-2016, 04:12 PM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
To answer your question, the best bang for your buck would be a homebrew system, or the stock FA20DIT retrofit.
As already mentioned, you want a system with a thermostatic switch.
Lot's of homebrew info here: http://www.ft86club.com/forums/showt...t=homebrew+oil
DIT info: http://www.ft86club.com/forums/showthread.php?t=50427
@Docmattic here is mine: http://www.ft86club.com/forums/showt...85#post2520685
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Dream20b (01-25-2016)
Old 01-25-2016, 10:30 AM   #8
Maximal
Maximal's Avatar
Drives: Dodge Stealth
We've had good luck with our kit here: https://www.maximalperformance.com/f...oil-cooler-kit
If you're interested in going the DIY route let me know and I can get you prices for the parts. We carry Mocal/Setrab so it's all quality stuff and the same things we make our kits out of.
Maximal is offline   Reply With Quote
The Following User Says Thank You to Maximal For This Useful Post:
tracerit (01-25-2016)
Old 01-25-2016, 10:42 PM   #9
stevo585
Drives: White 2014 BRZ
Does it have a thermostat?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 01-25-2016, 11:04 PM   #10
wbradley
Sarcastic SOB
wbradley's Avatar
CX Racing. Need a ton of Teflon tape for the threaded fittings, but its a big radiator, nice hoses and excellent mounting point. Mine sits in front of the radiator (behind intercooler). Not too sure how vital a thermostat unit is if the coldest if ever gets is -6C. You must be in the south, maybe Adelaide?
The Australian dollar exchange, shipping and tax considered, it's a good deal. Being in Canada, we're in the same situation with a devaluated currency and that motivated me off the beaten path of popular brand names. Once I discovered the need for copious amounts of Teflon tape I found the product otherwise highly acceptable.
Old 01-26-2016, 11:55 AM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I dont think the Forester oil cooler will be anywhere near enough for a Sprintex kit that already runs hot. The DIT retrofit is barely enough on an NA car (and thats debateable depending on your driving habits even)
Homebrew is definitely cheapest but the Maximal isnt much more and it comes with mounts and precut lines. It is essentiallly a premade homebrew if that makes sense
Hyper4mance2k (01-26-2016)
Old 01-26-2016, 12:18 PM   #12
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Agreed. Aside from a homebrew, it's probably the best bang for your buck.
I just don't like how tiny the oil cooler is, but it should fit 95% of peoples needs. I prefer to err on the side of caution by running the largest cooler that will fit, while keeping temps in line with thermostats.
Old 01-26-2016, 12:38 PM   #13
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
FA20DIT setup is good enough for most people.
For those looking for a plug and play unit, the Jackson Racing unit uses a nice large Setrab core with plenty of testing on the fittings and bracket/fasteners. The thermostat sandwich plate is a Mocal unit. The complete package comes with simple and easy to follow instructions to complete your install.
CounterSpace Garage is offline   Reply With Quote
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
firemedic1428 (01-27-2016), justint5387 (01-26-2016)
Old 01-26-2016, 12:39 PM   #14
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
FWIW, my Maximal oil cooler kept my oil temps in check fine in ~60 degree F track days. I'll have to see what it does in the dead of summer at 95 degrees, but even if it goes up 20 degrees I'm still safely within the limits of synthetic oil. That said, a bigger core mounted further back would definitely be a good thing and pretty much a requirement for FI. I really like the placement of the AVO oil cooler and their nice ducting for it. Too bad they use stupid SS braided lines and the install is a gigantic PITA.
Log from track day: http://datazap.me/u/docwalt/10-24-15...data=1-6-11-12
Bang for the buck - upgrades BAE Engine, Exhaust, Transmission 101 03-09-2015 08:23 AM
Best bang for my buck? ric342 Southern California 12 02-14-2015 07:09 PM
best bang for the buck HFC BlackyRose Engine, Exhaust, Transmission 11 08-25-2014 10:19 AM
Best bang-for-the-buck mods supramkivtt2jz Scion FR-S / Toyota 86 GT86 General Forum 65 04-28-2014 09:54 PM
Most bang for the buck? GIMMICK Scion FR-S / Toyota 86 GT86 General Forum 24 05-07-2013 07:10 PM
