Old 01-21-2016, 10:01 AM   #1
ka-t_240
Final Drive Swaps
Hey everyone,
I am looking at Final Drive swaps for my BRZ. I do a bunch of HPDE and now TT events, as well as autox.
What is your prefered FD, and have you played around with a couple different options? I have a lot of tracks where I spend a lot of time in the top of 3rd, or bottom of 4th in the corners.
BRZ is tuned on E/L Header, E85, etc. I run 245/40/17 street tires or possibly 225/45/17 "R Comps".
ka-t_240 is offline   Reply With Quote
Old 01-21-2016, 10:02 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I am planning on getting a 4.88 for street use
Old 01-21-2016, 02:53 PM   #3
TommyC
Drives: 2016 BRZ
I just bought a 2016 BRZ 6MT and my first though was "this needs a higher FD ratio"
I haven't researched what stock is, but it feels like 12-15% quicker gearing would be perfect.
TommyC is offline   Reply With Quote
Old 01-25-2016, 10:30 PM   #4
Slip Angle
Drives: Devolving WR Blue 6 Spd BRZ Limited
m factory 4.67 final drive impressions
I am very pleased with the improvement the m factory 4.67 gear ratio made for me on track. It does a great job at masking the lack of torque the brz suffers from. I can now hang with and pass a competent driver exiting corners in say, a spec e30 bmw track car where I previously got eaten up due to the lack of torque. It really makes the car more fun to drive and quicker particularly at corner exit which will improve lap times. Changing gear ratios is always with some trade off though, as it will improve gearing in some corners but may become less advantageous in others. I think a lot of guys shy away from this mod as it doesn't actually improve hp and is moderately labor intensive to install. Good luck, I don't think you'll regret doing it. Look around on this forum and you'll see that many of the well built cars have done a final drive swap 🏁
Slip Angle is offline   Reply With Quote
Old 01-26-2016, 01:55 PM   #5
ka-t_240
The work doesn't bother me one bit, my car is in storage and ill just try to find a spare diff to swap in. Then get the FD swap in and swap a diff out when i do my pre-season fluid changes.
Old 01-26-2016, 01:58 PM   #6
ka-t_240
I have to de-mod my car to make TTD, so figured that means I can use that money to pay for a FD swap. I have a lot of places on the 2 tracks I am at the most where I am holding like 6500rpm thru the corner as im not comfortable at the RPM where I am in the next gear. I was thinking with a different gear ratio it could help.
I have a chance to get a decent deal ona 4.44 M Factory setup from a semi local racer.
Old 01-26-2016, 06:57 PM   #7
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I have an M-Factory 4.44 FD. Just did my first event with it at Roebling Road this weekend. Really impressed with it. Still managed around 30mpg on the 5 1/2 hour drive there too. I run TTD with NASA.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 01-28-2016, 09:54 PM   #8
mrk1
Drives: Sterling BRZ Ltd
I've had 4.56 , 4.44 , 3.91 as my car has evolved. Changing FD really can change the profile of the car to fit your needs.
Sound to me like a 4.56 would fit your needs.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
Final Drive: 4.56 vs. 4.88 mcbrawr Engine, Exhaust, Transmission 43 12-26-2015 07:23 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 07:36 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 07:55 AM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
